It is currently Mon Jan 22, 2018 9:22 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Wed Nov 27, 2013 2:56 am
I have a 695. You need should get the Look bolts. They are slightly longer. Careful though as the slightest amount of over torque will break them.
PostPosted: Sat Jul 15, 2017 10:53 am
Hey 695 owners, I have a problem/question.
I was lucky enough to buy a used bare frame in great condition which I'm building up.
My problem is the fd cable routing up through the frame from underneath.... cant get the fd cable straw/outer/guide/whatever you call it through behind the BB.
There's a hole under the BB just past the nylon guide, and a hole on the flat area between the rear stays, but there seems to be no tunnel between the two! I've tried pushing a skewer in at each end and seem to hit something solid at a shallow level (which ging in from underneath) and deeper going in from on top.
Does anybody know what's going on here?
Thanks!
There are no new unread posts for this topic. Stems with internal cable routing
murphyk
Fri Oct 13, 2017 4:14 pm
kode54 View the latest post
There are no new unread posts for this topic. Compressionless brake housing for internal routing
bikewithnoname
Sun Apr 16, 2017 7:43 am
bikewithnoname View the latest post
There are no new unread posts for this topic. Cable routing tips for a Di2 newbie
simurs4
Tue Feb 28, 2017 4:50 am
jlok View the latest post
There are no new unread posts for this topic. Attachment(s) Routing rear brake cable
Lightweenie
19
931
Wed Nov 29, 2017 10:27 am
Fiery View the latest post
There are no new unread posts for this topic. Campag shifters: which is the best gear cable routing to use?
wilwil
Thu Jan 11, 2018 11:41 pm
Calnago View the latest post
Users browsing this forum: benzebub, Bing [Bot], Jereb, JS300, wingguy and 44 guests
