It is currently Mon Dec 18, 2017 5:45 pm
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: Creaking Sram S950...
PostPosted: Sat Jul 20, 2013 1:27 am
I run S950 cranks on a lot of my bikes because I like the versatility of the BB30 version... it can fit in a traditional frame similar to Rotor or Zipp Vuma and can slip into a BB30 frame.
That said, one of mine (only with 3300 miles on it, but 4 seasons old) has recently developed quite a loud creak when under power. Through much trial and error I've isolated it to the interface between the drive side crank arm and the spider. The spider is attached to the arm with three small bolts. I've removed the entire assembly and re-greased it, and reattached it quite tightly, but the creak continues. There is some play between the spider and crank arm, but there is no sign of wear, so I cannot pinpoint if the issue is the spider or the crank arm.
Does anyone have experience with this, and if-so, what did you do to fix it?
PostPosted: Sat Jul 20, 2013 3:32 am
I had a similar issue - my problem was that one of the Torx head bolts had cracked.
PostPosted: Mon Jul 22, 2013 4:25 am
I just had the whole thing apart and didn't notice any cracked bolts. Very strange. I'm considering replacing the spider to see if it makes any difference. I'm not sure if the crank or the spider would have the harder alloy...
It is certainly annoying when climbing out of the saddle though! There's no sneaking up on anyone on a climb with that bike right now...
PostPosted: Mon Jul 22, 2013 10:59 am
Maybe it would help if you would put some grease on the interface?
My Renovo R1 wooden bike project and the reason for my passion for all that is wood.
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Wed Jul 24, 2013 4:07 am
Tried the grease route when I took the assembly apart... no change. Thought about using Tacx carbon assembly compound instead but didn't want to run the risk of any of it reaching the spindle and bearings.
PostPosted: Wed Jul 24, 2013 6:37 am
you should use the folowing:
Retaining Compound 638 or 680 (RC-Adhesive)
Threadlocker 242 (TL)
Note:RC 680 comes in 0.5mL vials, and is not as
viscous as 638 both perform identical.
both are locktite products. I got this information from Quarq when changing the spider from a gxp crank to BB30 if you email me I can send you a pdf with complete instructions
salomon.pete@gmail.com
There are no new unread posts for this topic. Help me tracking down creaking
nemeseri
Sat Jul 29, 2017 10:14 pm
rmr40 View the latest post
There are no new unread posts for this topic. Another Creaking Noise Question
ipenguinking
14
628
Sat Dec 02, 2017 9:45 pm
ipenguinking View the latest post
There are no new unread posts for this topic. Terrible creaking on madone 9
markyboy
29
2095
Tue Oct 17, 2017 11:55 am
markyboy View the latest post
There are no new unread posts for this topic. Help me fix my CREAKING bb30 bottom bracket
jobvisser
33
2871
Wed Apr 05, 2017 2:11 am
glepore View the latest post
There are no new unread posts for this topic. Seatpost creaking in frame (and ideal insertion)
Alexandrumarian
9
591
Sun Oct 08, 2017 7:07 pm
Alexandrumarian View the latest post
Users browsing this forum: Bing [Bot], BobbySweeting, Catagory6, coriordan, Google Adsense [Bot], KarlC and 41 guests
