It is currently Tue Jan 17, 2017 8:31 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Fri Jul 19, 2013 7:19 pm
My friend bought a Specialized Amira for his daughter. She's 11 yrs old, racing U12 category.
She has to use a 42T front Chainring for best ratio at 42 X 16 ( 6.00 meters ).
But the FD is a braze-on on the Amira, and at the lowest, is more than 8-10 mm over the big chainring, and the gear changes are a mess. The chain always drops over the big ring.
Any other options that wouldn't penalize the 6 meters ratio ?
I though putting a home-made "squared" 34.9 mm (I think we'll need bigger than that) clamp to the squared seat-tube below the braze-on till next year (she'll be U14 and then can use a 46T front chainring)...
What else ...?
Louis :)
PostPosted: Sat Jul 20, 2013 7:19 am
SRAM Braze-on FDs have two mounting positions. Or at least on the Red models.
Have you taken a look at those? Maybe it can get low enough for you
Bike: Felt FC
Strava
PostPosted: Sat Jul 20, 2013 10:22 pm
Sadly, that's probably not low enough. I have a Rival derailleur on the same bike as a 46t chainring, and it's about 4mm. It's functional, but not particularly smooth. I guess it's better than nothing at all though, so that's a reasonable fallback for OP.
PostPosted: Sun Jul 21, 2013 2:05 pm
Yes, that's one of the "least worst" options for now. Using a 46T front chainring, but I'm shure that'll penalise her with the ratio, as 46-17 will probably be over 6.00 m (illegal) , but 46-18 will have her lose ground every pedal stroke...
I had an Excel file somewhere, but can't find it. probably 45T X 17 would bring her close to max 6.00 m .
Louis :)
PostPosted: Mon Jul 22, 2013 12:29 am
Hmm maybe possible to create a bracket the shape of the braze on mount with a hole for the derailleur bolt where you need it.then you can bolt the bracket to the braze on..
Now I know the u12 category is super competitive and serious business but how many more races does she have to be disadvantaged until next season?
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Mon Jul 22, 2013 1:41 am
Good idea crohnsy. Brobably easy to to do as well :thumbup:
I know. But at the same time, when you're at your second and last season under a category, you want to perform at your best. Still 5 races to go, maybe 6...
Next year, she'll get the 46 X 16 ratio, the shifting "problem" will be resolved, but she'll be 1st year U14...struggling against the "big girls" again...
Louis :)
PostPosted: Tue Jul 23, 2013 11:59 am
Rotor makes some shims that moves the derailleur back 6mm, and also a shim that is tapered 6mm/4mm (top-bottom). That should move the derailleur enough to make it shift ok.
There are no new unread posts for this topic. Bike Mechanics in London
condorman
Tue Aug 09, 2016 11:04 am
sungod View the latest post
There are no new unread posts for this topic. BMC seat clamp size
Serrom
Tue Oct 04, 2016 9:41 am
pressed001 View the latest post
There are no new unread posts for this topic. Torque for seatpost clamp
Tubby16
Wed Jan 04, 2017 8:04 am
Tubby16 View the latest post
There are no new unread posts for this topic. Additional seat clamp
zazo
14
674
Fri Jan 13, 2017 8:16 am
Fiery View the latest post
There are no new unread posts for this topic. Is this the lightest ahead clamp/ expander?
wheelsONfire
Mon Aug 01, 2016 6:12 pm
wheelsONfire View the latest post
Users browsing this forum: Baidu [Spider], bfno, campbellrae, Klaster1, maxxevv, Yahoo [Bot] and 31 guests
