Shimano Di2 9070 internal battery charger
biotin
by biotin
Hi ,
My next frame can only be install with di2 internal battery .Shimano BTR2
I knew that SM-PCE1 can be use for diagnostics/firmware update . Can it be use to charge the battery as well ?
Or I still need SM-BCR2 to charge the battery.
p/s - i will list my new external di2 battery/charger soon . not needed
Thanks
Tamu8104
by Tamu8104
You need the SM-BCR2 to charge the battery. I had a SM-PCE1 but it wouldn't charge the battery. The SM-BCR2 has a different cable that plugs into the front junction box, not your standard e-tube like the SM-PCE1.
Gaulzetti Cabron Disc = (weight unknown)
Rock Lobster Team Tig SL Disc = (pending)
Sold: Ridley X-Night Disc = 7.80 kg | Ridley Noah FAST = 6.86 | Ridley Fenix = 6.74 | Raleigh HiLife = 7.46 | Fuji SST = 7.34 | Van Dessel FTB = 7.58
biotin
by biotin
oh great , need to spend more just on the charger alone . With SM-BCR2 , I still can update firmware except diagnostics, right?
rmerka
by rmerka
You can update the firmware AND charge the battery with the SM-BCR2. You don't need the SM-PCE1.
biotin
by biotin
Then why shimano came out with PCE1 which is slightly expensive ?
SvenNijs
by SvenNijs
biotin wrote:Then why shimano came out with PCE1 which is slightly expensive ?
Because they didn't have the SM-BTR2 & SM-BCR2 ready for the market when they first released the PCE1?
BdaGhisallo
by BdaGhisallo
Do keep in mind that if you have any issues and need to run any diagnostics on your DI2 E-Tube components, you will need the PCE1.
