It is currently Mon Dec 18, 2017 4:14 pm
Post new topic  Reply to topic  [ 5 posts ]
 Post subject: Scott steerer plug?
PostPosted: Wed Jul 17, 2013 10:16 pm
Not seen one like this before I got the bike, it's an older ('09) Scott CR1.
What do I do with this when cutting the steerer? I've only used regular
compression plugs before which are obviously much easier...
Campagnolo; because it's a bicycle, not a fishing rod.
 Post subject: Re: Scott steerer plug?
PostPosted: Wed Jul 17, 2013 10:43 pm
A hex key should loosen that guy up for you to remove...
PostPosted: Wed Jul 17, 2013 10:47 pm
Ah okay. Don't have one big enough so I'll ask around and see what I can do. Thanks!
PostPosted: Thu Jul 18, 2013 3:25 pm
Yes, there are actually two hexes. The smaller one down further in the compressor, that is the one that actually controls the compression piece.
Then that bigger diameter one, I think it is like 8mm if I recall. For the top portion. You want to loosen the top/bigger one first, then the bottom compression piece.
The top piece which screws into the lower compression portion doesn't go down into the tube at all as you can see, designed to sit on the top lip.
Install the opposite. Get the bottom/smaller hex and compression set so it just touches the fork tube. Lower it down and start to tighten it at the depth you want, then tighten it up.
Then screw the top portion down and tighten with the bigger hex. Now you can screw the top cap through to the compression portion to tighten the headset up to desired level.
Real simple once you get the right hex wrench sizes for the job.
Good luck.
PostPosted: Thu Jul 18, 2013 3:55 pm
Thanks, will source some tools and post results.
There are no new unread posts for this topic. Canyon Ultimate SLX 8.0 steerer plug adjustment
peterpen
13
1809
Mon Jan 09, 2017 7:44 pm
dondomingo View the latest post
There are no new unread posts for this topic. Attachment(s) Canyon aeroad steerer plug adjustment
dannyBBo
Mon Aug 07, 2017 2:21 pm
alcatraz View the latest post
There are no new unread posts for this topic. compression plug
addictR1
13
805
Sun Dec 03, 2017 12:39 pm
Lewn777 View the latest post
There are no new unread posts for this topic. Expander Plug for Canyon
markgoldstein
9
1310
Tue Jun 20, 2017 1:52 pm
markgoldstein View the latest post
There are no new unread posts for this topic. Recommend a decent easily available compressor plug thing
Shrike
Fri Jan 13, 2017 9:23 pm
Attermann View the latest post
Users browsing this forum: AJS914, djwalker, Google [Bot], Google Adsense [Bot] and 46 guests
cron
