nylon and ti screws where do you get
liketoride
by liketoride
I was thinking of changing my bolts but i am not sure what size all the 12-13 reds use? where would i find that info out? i also wondered where you recommend sourcing the bolts? thanks.
drainyoo
by drainyoo
Here a list of bolt sizes for each part:
http://weightweenies.starbike.com/articles.php?ID=16
You can get bolts from a few places: Jersey Cycles, Toronto Cycles, Racebolts. Some more here: http://weightweenies.starbike.com/faq.p ... _buy_bolts
liketoride
by liketoride
thanks for the info i can take it apart and find out what size bolts they are. thanks again
liketoride
by liketoride
how can you tell what bolt material you are working with? i would not want to change something that is lighter already?
aaric
by aaric
Nylon - its plastic. Very apparent by looking at it.
Steel vs Ti: Use a magnet. You can generally tell by feel as well, as steel is significantly more dense.
Ti Vs aluminum: Aluminum generally is quite a bit softer, and is a different color. I don't think its very common to find stock though. Perhaps water bottle screws.
coloclimber
by coloclimber
Buy a time frame and you get carbon fiber water bottle screw for free. I kept them when I sold the Time and they have served me on two different bikes now.
-Deacon Doctor Colorado Slim
liketoride
by liketoride
am i correct to think nylon bolts are lighter than carbon? thanks for all the help above.
coloclimber
by coloclimber
I cant recall if nylon or carbon is lighter. Bottom line- within a 1gram. Both are lighter than ti or aluminum .Image
liketoride
by liketoride
Thanks to all you have been a big help i will report back how much wt i take off. thanks again.
liketoride
by liketoride
i just came across this site and it might help someone else too
http://faqload.com/faqs/bicycle-compone ... rbon-fiber
liketoride
by liketoride
can someone help me with what they think this is please the fd screws are steel and i think the back ones are alu but i just want someone to confirm and i was wondering if anyone knew the jockey screw was
http://www.flickr.com/photos/99184869@N08/9318231803
http://www.flickr.com/photos/99184869@N08/9318231557
liketoride
by liketoride
it is not loading the pics how do you load the pics in the text?
