Dura-Ace Di2 9070 - compatible with 10-speed?
415brian
by 415brian
Confirmed. The RD determines 10 vs. 11 speed. So both of these scenarios work:
1. Full 6770 (10 speed) modified to 11 speed: add 11-speed cassette (requires compatible hub), 11-speed rear derailleur & 11-speed chain.
2. Full 9070 (11 speed) modified to 10 speed: add 10-speed cassette (and spacer) and 10-speed rear derailleur.
tmunk
by tmunk
415brian wrote:Confirmed. The RD determines 10 vs. 11 speed. So both of these scenarios work:
Thanks Brian! I assume in my case since my hub would still be 10-speed that I wouldn't need to use any kind of spacer.
P.S I'm still not clear as to when you need to use the 1mm spacer with Shimano cassettes. I've heard that you should use it on any hub that is SRAM/Shimano compatible...but not on Shimano only hubs.
Todd.
FIJIGabe
by FIJIGabe
Also, for you guys who have 10-speed wheels that can't be converted, swap on a Campagnolo 11-speed freewheel and run their 11-speed cassettes. Many on the forum have tried it, and it works.
Pokerface07
by Pokerface07
For what it's worth, I have the Dura Ace 9070 levers and front mech on my bike and the 6770 rear mech. Lightest 10-speed setup you can get with newer parts. Works really well.
