It is currently Tue Jan 24, 2017 6:00 am
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3 Next
 Post subject: DA 9070 Running 10 Speed
PostPosted: Sat Sep 07, 2013 11:17 pm
Picked up DA 9070 for my Noah because I wanted to drop some weight. Initially, I didn't buy a 11 spd cassette as I wanted to see if I could run it as 10 spd. I was running Ultegra 6070 prior to this.
I received the derailleurs (still waiting for the shifters to arrive) and installed them. For the rear, I tuned the derailleur on the 13t and used the lower limit screw to block off the 11th gear. Set the front up as normal. On the work stand, it appears to shift REALLY well, possibly as well as the 6070. I'm running a SRAM 1090 rear cassette and Quarq with the 9070. The chain is a KMC X10SL that is near the end of it's life. I ordered a KMC X11SL that will probably help the 9070 even more. Tomorrow I'll take it out and see how it shifts under load.
Super excited about dropping 118g (derailleurs only) and waiting to change to 11 spd till I'm ready to do the TT bike as well.
Gaulzetti Cabron Disc = (weight unknown)
Rock Lobster Team Tig SL Disc = (pending)
Sold: Ridley X-Night Disc = 7.80 kg | Ridley Noah FAST = 6.86 | Ridley Fenix = 6.74 | Raleigh HiLife = 7.46 | Fuji SST = 7.34 | Van Dessel FTB = 7.58
PostPosted: Sun Sep 08, 2013 4:07 am
I am very interested to see how this works
PostPosted: Sun Sep 08, 2013 4:39 pm
So did a short ride today and it worked well. Had to tweak the limit screw a little to account for the auto trimming but that was it. No ghost shifting or shifts not completing. That said, this wasn't an all out effort but I did an opener, a sprint, and a couple of short steep ramps and no issues in any of it. Post ride I did this little video so you can see how it shifts.
http://youtu.be/_WxiCBsJEEU
PostPosted: Sun Sep 08, 2013 4:53 pm
Instead of shifting gears continuously, how about keeping it in each gear for a while so we can hear how it sounds?
PostPosted: Mon Sep 09, 2013 3:52 am
I'm under the impression that the limit screws on the Di2 is a mechanical and not an electrical stop. If the derailleur is already at the limit and you tried to shift to the 11th cog the motor will likely break.
PostPosted: Wed Sep 11, 2013 2:22 am
I didn't see any option to make 9070 RD a 10-speed compatible one in the programming software, but I guess you can do that by using limit screws as discussed above. if it is the wheels, I would switch to Campy cassette body to make it 11 compatible
PostPosted: Sun Sep 15, 2013 10:26 pm
So I installed the DA levers and also a KMC X11SL chain. The 11 spd chain shift about the same on the rear but didn't like the Rotor rings up front. Try as I might, I couldn't get it to shift cleanly up front. It would ghost shift or have a hard time engaging under load. Switched back to a 10 spd chain and it's fine again. I took another video. There is noise in the 12, 13, and 14 in the video. After the video I adjusted the rear down one click and that resolved most of that.
http://youtu.be/jFKsKiCZRTE
PostPosted: Mon Sep 16, 2013 12:42 pm
No, the system stops pushing once it hits the limit. Otherwise it would constantly be straining against its limits.
I've worked on a system where a junior had to use the limits on a 6770 setup to block out the smallest 2 or 3 cogs. It made shifting weird since there were effectively some dead shifts, but it worked ok.
Blog: http://thesetbackpost.com/
PostPosted: Wed Sep 18, 2013 8:13 am
I don't know where you got your info. but I got mine from the Shimano dealer manual. Below is an excerpt taken on page 53.
Phenomenon that occurs due to an excessively
tightened adjustment bolt
••Gears do not shift to the top/low gear.
(Even if you shift gears to the top or low gear, the gear may shift
back by one gear after about 5 seconds.)
••Noise does not stop.
••Battery charge disappears quickly.
(load is being placed on the motor.)
••The motor may be damaged. (irreparable)
PostPosted: Thu Sep 19, 2013 1:44 pm
and about using this setup:
Ultegra di2 Shifters (10V) with a 9070 Di2 RD + a 10 speed cassete ?
PostPosted: Thu Sep 19, 2013 1:49 pm
Tinker, Taylor, Tart
^^ That setup will result in 11spd. It's the rear mech choice that determines the 10/11spd setup.
Running full DA 9070 Di2 with an Ultegra 6770 Di2 rear mech = 10spd.
PostPosted: Thu Sep 19, 2013 7:26 pm
Anyone who has been able to connect the internal/ seat post battery to an old 7970 groupo? I know that the connectors don't match, but that can be solved.. questions remaining is will it work and how to charge. Any DIY tips?
PostPosted: Fri Sep 20, 2013 12:15 am
Online
Why bother? Aftermarket Lipo batteries for 7970 are easy to get, and easy to make. Depending on your proficiency with a soldering iron, you can buy the raw materials and do it yourself very cheaply, or you can buy a ready made one with correct harness and charger.
PostPosted: Tue Sep 24, 2013 4:26 pm
Is it indeed just the rear-mech that decides about 10 or 11 speed? So would -RD-9070 + FD-6770 work at 11 speed without issue? (Currently gathering items for a UDi2, and just need a RD + Junction-A now, and if switching to RD-6870 would suffice to make it work 11speed would of course be a great option over having to also replace the FD-6770 I already have).
PostPosted: Sat Nov 09, 2013 12:02 am
I have a couple wheels that can't be converted to 11-speed. They are expensive wheels too (ZIPP's) and in excellent condition.
I saw a couple posts saying you could use a DA 9000 DI2 group with a UI2 6700 rear derailleur/cassette and get 10-speed?
Can someone verify this?
This would be the ideal situation for me as I really want to use the DA groupset (LOVE the shifters) but can't convert my wheels.
Todd.
There are no new unread posts for this topic. Is 11 speed Dura Ace chain compatible with Dura Ace 7900 gruppo?
wootenlakeguy
Thu Oct 13, 2016 7:07 pm
pdlpsher1 View the latest post
There are no new unread posts for this topic. Dura Ace 9070 Di2 for Pinarello F8
fh8425
Sat Jun 25, 2016 5:28 am
fr1 View the latest post
There are no new unread posts for this topic. Dura Ace 9070 DI2 shifters with Ultegra 6870 derailleur
muntos
21
1588
Thu Feb 18, 2016 7:32 am
eaglejackson View the latest post
There are no new unread posts for this topic. Dura Ace 9070 Rear Mech Hanger stiff problem
TheDarkInstall
Sun Jun 05, 2016 5:47 am
TheDarkInstall View the latest post
There are no new unread posts for this topic. Need a super cheap temporary 11 Speed shimano compatible chainset
Shrike
9
437
Wed Jan 18, 2017 2:35 am
mpulsiv View the latest post
Users browsing this forum: Baidu [Spider], Exabot [Bot], Google [Bot], Google Adsense [Bot], Inspire, jj911c2, MSNbot Media, numbers505, Yahoo [Bot] and 31 guests
