Post new topic Reply to topic  [ 5 posts ]
PostPosted: Fri Jan 30, 2004 12:46 pm
Im switching from old dura ace to '04 record, and I've looked at the tiso and BTP cassettes, has anyone used any of theese cassettes? is shifting worse than with campy ones?
thanks,
Gonzalo
PostPosted: Fri Jan 30, 2004 4:02 pm
thanks,
Gonzalo
I've used the Tiso cassettes.
Both MM10 and normal Campy 10v models. They work well, the only change I found useful was to use a slimmer 3.0mm spacer that fits on the body before the first sprocket. This moves everything further in slightly so it was in the same position as wheels using Campy original cassettes. After doing this I could change wheels without having to adjust the shift setup.
I found shifting to be good with the Record chain, noisier with the Wipperman chain. Only good for about 1,200 miles though.
I use them on my weight weenie wheels, for normal use I have Record cassettes instead.
The BTP cassette looks like one of these with a steel top sprocket. Token guarantees them for 2,500km (1,560m). I have one for my Stiletto Light wheels in an 11-25t configuration to try come March :D
Ride lightly!
 Post subject:
PostPosted: Fri Jan 30, 2004 5:16 pm
I've just ordered a cycledynamics full titanium cassette.. should arrive in 7 days time :D
cost for a camapg 12-21 9-speed casssette plus additional 23 and 25 tooth sprockets was $155.. Great price if you're not in the USA!! Quoted weight is 124g for a 12-21.
Will post on here when I get it about shifting performance.
Doozer :mrgreen:
Dance you cares away, worries for another day, dance your cares away, down at fragglerock.
 Post subject:
PostPosted: Fri Jan 30, 2004 8:06 pm
I had one of the early Tiso cassettes and was running the Tiso rear der. with it and it shifted terrible. Since then they have added ramps to the cassettes and they sent me one as a replacement. The new version shifts really well. I only have about 80 miles on it and the more it gets broken in the better it shifts.
 Post subject:
PostPosted: Sat Jan 31, 2004 11:23 am
http://www.interlocracing.com/cassettes.html
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], Johnny Rad, shimmeD, spookyload, tommasini and 41 guests
There are no new unread posts for this topic. Tiso 12 speed electronic is here
artray
12
1688
Fri Dec 14, 2012 3:16 am
Privateer View the latest post
There are no new unread posts for this topic. 12 speed Tiso electronic wireless
spandexboy817
9
1215
Fri Nov 30, 2012 11:48 pm
bm0p700f View the latest post
There are no new unread posts for this topic. 12-30 cassette fitment
plpete
Thu Aug 16, 2012 8:07 pm
eric View the latest post
There are no new unread posts for this topic. Chorus cassette
wasabi1
Thu Aug 09, 2012 11:05 pm
wasabi1 View the latest post
There are no new unread posts for this topic. 12-27T Cassette options?
WeightySteve
19
1235
Sun Aug 12, 2012 2:42 pm
WeightySteve View the latest post
It is currently Fri May 24, 2013 6:02 am
