It is currently Wed Jan 17, 2018 12:27 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page 1 2 Next
 Post subject: Deciding on Cranks
PostPosted: Sat Jul 13, 2013 2:50 pm
I'm deciding between these cranks: Cannondale Si, SRAM Force and Specialized S-Works. These are all older models and I'm interested in these because I can get them all brand new at a great price, and I also want the carbon weave look just for aesthetic reasons. So I wanted to get some feedback on these cranks to see which one is the stiffest, most reliable, lightest and if any have any big issues. The crank will go onto my CAAD10 and I will be using Fibre-lyte rings. The Force has a GXP BB, so I will need an adapter for it. The others should fit fine. Any advice would be appreciated. Thanks!
6.24kg CAAD10
 Post subject: Re: Deciding on Cranks
PostPosted: Sat Jul 13, 2013 2:58 pm
I'd prefer not to run SWorks cranks on a Cannondale, and I think the SRAM crank is aesthetically 2nd to the Cannondale.
PostPosted: Sat Jul 13, 2013 2:59 pm
Cannondale Si
My 6532gr TIME Skylon
My 9733gr COLNAGO Master X-light
PostPosted: Sat Jul 13, 2013 3:17 pm
The Cannondale's are my top choice, but wasn't there a recall for them a few years ago?
6.24kg CAAD10
PostPosted: Sat Jul 13, 2013 4:30 pm
i don't remember if there was a recall or not. I do remember that the pedal socket use to pop out of the crank arm. I don't recommend using that particular model
PostPosted: Sat Jul 13, 2013 4:41 pm
I did not know that. Thanks for the info.
Anyone know the weights of the Force crank arms?
6.24kg CAAD10
PostPosted: Sat Jul 13, 2013 4:55 pm
Yes,there was a recall for the CD Si cranks where FSA was blamed to have incorrectly heat treated some of the BB spindles.
PDF file dates back to May 2007 .
Kuota Kom Evo
viewtopic.php?f=10&t=111825&p=955235#p955235" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
SOLD
PostPosted: Sat Jul 13, 2013 5:04 pm
Thanks. Cannondale's are off my list.
6.24kg CAAD10
PostPosted: Sun Jul 14, 2013 12:01 am
The force cranks are aluminum wrapped in carbon. I have a pair. They're not light. My FSA SLK lights are about 150 grams lighter. Sram's bottom bracket system for threaded BB's is a lot better than most though. Yeah, they're heavier, but require zero maintenance and the bearings last forever.
PostPosted: Sun Jul 14, 2013 12:42 am
Didn't know that. Wonder if the Specialized are full carbon. Do you have a weight for the Force arms?
6.24kg CAAD10
PostPosted: Sun Jul 14, 2013 12:48 am
Go for the Speci's......sand them.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Sun Jul 14, 2013 12:56 am
Sand them? Why?
6.24kg CAAD10
PostPosted: Sun Jul 14, 2013 1:13 am
To get the S-Works labeling off since it would look silly on a Cannondale.....
Mosaic RS-1
PostPosted: Sun Jul 14, 2013 1:32 am
Haha oh, I don't care about that.
6.24kg CAAD10
PostPosted: Sun Jul 14, 2013 3:12 am
If i did decide to remove the label, would the sanding scratch up the carbon?
6.24kg CAAD10
There are no new unread posts for this topic. What factors do you consider when deciding to buy a new frame?
wwnick
21
1368
Sat Jul 01, 2017 5:27 pm
MiddMan View the latest post
There are no new unread posts for this topic. Help deciding on crank arm lenght
apctjb
12
1046
Mon Nov 20, 2017 5:58 am
grover View the latest post
There are no new unread posts for this topic. Short Cranks
morganb
Sun Apr 09, 2017 3:16 am
Valbrona View the latest post
There are no new unread posts for this topic. Attachment(s) 165mm cranks
peted76
24
2773
Wed Feb 15, 2017 2:20 pm
WhyZ View the latest post
There are no new unread posts for this topic. Lightning cranks
nickf
16
2295
Tue Sep 26, 2017 11:53 pm
alcatraz View the latest post
Users browsing this forum: Ettore, Greatestalltime, wingguy and 44 guests
cron
