It is currently Thu Jan 18, 2018 5:15 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Tue Jul 09, 2013 10:38 pm
Hey guise. I recently ordered a Scott CR1 Pro frameset, which uses BB30, which means I'm gonna be needing a crankset in a week or so. I've narrowed my choices down to SRAM Red, FSA SL-K Light, and FSA K-Force Light (but I'm definitely open to suggestions). However, I've also seen the SRAM S951 and from what I've read, it has a yaw feature that seems to be only compatible with the SRAM Red derailleur.
I'm gonna be running full Shimano 105 on my rig. Would the S-951 give me problems? Thanks~!
PostPosted: Wed Jul 10, 2013 1:12 am
The CR1 pro doesn't use BB30. The crankset would probably work fine, but stick to GXP if you're going to use SRAM
PostPosted: Wed Jul 10, 2013 2:06 am
You'll need the Sram PF86 bottom bracket to go with the S951 crankset (GXP...as pointed out above). There's really nothing "yaw" about the cranks other than their compatibility with the Red Yaw FD. You'll probably find "best" (as opposed to "adequate" or "good") shifting by using Shimano rings though.
PostPosted: Wed Jul 10, 2013 4:02 pm
Actually, the CR1 pro frameset is PF86, not BB30. Unless their website is a liar.
There are no new unread posts for this topic. Hollowgram vs Sram Red cranks
TLN
Thu Jan 04, 2018 11:13 pm
Nixster View the latest post
There are no new unread posts for this topic. Comparing weights: new generation shimano cranks vs previous
alcatraz
Fri Jan 12, 2018 9:24 pm
Marin View the latest post
There are no new unread posts for this topic. Attachment(s) Sram Red BB30 cranks & BB30A
meanmachine
7
2479
Mon Apr 03, 2017 5:08 pm
Valbrona View the latest post
There are no new unread posts for this topic. needing help Quarq cranks Sram and rotor, swapping them between bikes.
charlie0
Sat Sep 30, 2017 12:12 am
alcatraz View the latest post
There are no new unread posts for this topic. Mixing SRAM and Shimano
slowK
7
728
Thu Aug 24, 2017 10:23 pm
slowK View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], darnellrm, erik$, MoreRideTime, WESTMOTORSPORTS and 58 guests
cron
