It is currently Sat Jan 20, 2018 4:31 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Mon Jul 08, 2013 8:01 pm
Does anyone know if the Alfina display will work with the 9070 DI2 system? Just wondering as it would look kind of cool :)
PostPosted: Mon Jul 08, 2013 11:19 pm
I've seen the diplay connected in this Japanese blog. Although post most talks about something else.
http://blogs.yahoo.co.jp/ovestboss12/63541043.html
PostPosted: Tue Jul 09, 2013 12:47 am
When is the Di2 Computer Head Unit coming?
PostPosted: Tue Jul 09, 2013 3:36 pm
I can't find where I read it, but yes it will work. What I don't know is whether it would require the 5 port junction or if it passes through (like the satellite shifters) so that you can use the more common 3 port junction.
PostPosted: Sat Apr 04, 2015 4:03 pm
Just in case anyone else stumbles across this thread whilst googling, like I did.
I was looking to use an Afline display instead of a regular A-junction so I could have the gear display. The Alfine display only has 2 ports (vs 3 of a regular A junction) so I planned to run a wire from the left shifter to the spare port on the right shifter and the regular right shifter wire to the Alfine display which then went onto the B junction. Whilst it sounded good in theory I came across the following when researching if it would work.
Yes you can use the Alfine Display (SC-S705) unit with a 6770/6870/9070 Di2 system INSTEAD of a regular A-junction unit as per Shimano's compatibility chart. The Alfine unit has a port for charging an internal battery as well. But there are the following two caveats as there is no button on the Alfine display (unlike the regular SM-EW90A/B or SC-M9050). 1) You cannot adjust derailer trim on the bike and will need to connect the bike to the E-tubes software to do so. 2) Recovery from rear derailer protection is not possible (and I don't think you can even connect to E-tubes to undo the protection).
If you're using the Alfine display in ADDITION to a regular A junction then you would be able to do the above two points through the button on the regular A junction.
The XTR Di2 display is ~30g vs ~10g SM-EW90A (3 port) A junction.
There are no new unread posts for this topic. Wahoo Element Bolt - negative display field?
Shrike
16
1021
Fri Nov 17, 2017 11:07 am
Jensa View the latest post
There are no new unread posts for this topic. Shimano SC-MT800 display compatible with SM-BTR2 Battery?
velobob
Thu Oct 26, 2017 8:42 pm
egebhardt View the latest post
There are no new unread posts for this topic. Shimano 11-30 cassette with 9070 Di2
mnmasotto
7
969
Tue Sep 12, 2017 3:24 pm
MXGimp View the latest post
There are no new unread posts for this topic. Di2 Rear Mech | 9070 to 9150.
p3dalfaster
Wed Jul 05, 2017 7:29 pm
LeviR View the latest post
There are no new unread posts for this topic. Can I add a new 9150 Di2 Battery with blue tooth to my 9070
mnmasotto
Sat Mar 11, 2017 9:23 am
TurboKoo View the latest post
Users browsing this forum: coriordan, crn, Leviathan, mattcooke, petromyzon and 52 guests
cron
