It is currently Tue Jan 23, 2018 5:34 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Mon Jul 08, 2013 4:47 pm
Has anyone tried Sram 22 levers with new Red cranks and or derailleurs? When new Red came out it was said that you could not mix it with old cranks and levers but there were many combinations that worked fine. I have old levers and new cranks and new derailleurs and that combo works great.
PostPosted: Mon Jul 08, 2013 5:38 pm
It should be fine in the front, but you have an extra gear in the back that might not be too happy. You should be able to adjust so that you use all but the "lowest" gear in the shifter and have it max out against the low limit screw, giving you an effective 10s shifter.
Seems a bit silly though, using a more expensive 11s shifter when you just need the 10s one.
PostPosted: Mon Jul 08, 2013 6:07 pm
11sp spacing is different from 10sp spacing. I doubt it will shift correctly on a 10sp cassette. If the pull ratio is the same on 11sp vs 10sp deraileuer then 10sp derailleurs should work on an 11sp cassette with 11sp shifters.
I think this has been discussed on another thread so you may find the pull ratio answer if you search.
PostPosted: Mon Jul 08, 2013 8:30 pm
Obviously an 11 speed cassette. Why would one buy 11speed levers and not a 11speed cassette?
PostPosted: Mon Jul 08, 2013 8:42 pm
In that case you do definitely need the 11s chain. From what I understand, 10s crankset/front shifter/FD work just fine. Shifting is a weeeee bit off up front because the 10s derailleur has a wider cage for the 10s chain, but it's still perfectly doable.
There are no new unread posts for this topic. Beast Components Germany
mike001100
Mon Jul 10, 2017 8:00 pm
mike001100 View the latest post
There are no new unread posts for this topic. JRC lightweight carbon components
sussexhills
15
2111
Wed Nov 22, 2017 9:22 am
Jenmoss View the latest post
There are no new unread posts for this topic. Your bike: sum of components or aesthetically approved
Alumen
15
1660
Sun Sep 17, 2017 10:39 am
Juanmoretime View the latest post
There are no new unread posts for this topic. RD-R9150 shifting issue with 9070 components
ottavik
Sun Mar 12, 2017 8:04 pm
spartan View the latest post
There are no new unread posts for this topic. Attachment(s) Simple, safe and tough components that save weight.
Lewn777
26
4093
Sat Jun 24, 2017 2:14 am
BikeAnon View the latest post
Users browsing this forum: Bing [Bot], Wookski and 30 guests
