It is currently Tue Sep 19, 2017 1:10 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Sun Jul 07, 2013 11:36 pm
Really like how they feel but I get minor rubbing on non drive side .
Wheels sit slightly closer to that side and when I rand Scott they said it was normal and should not use 25mm tires
Is this correct ? anything I can do to remedy ? Should I just not worry about slight rubbing ?
PostPosted: Sun Jul 07, 2013 11:40 pm
Is your wheel out of dish? Where is it rubbing? What rims are you using?
I've just put 25mm Veloflexes on my Addict R3 with 23mm wide rims and there's lots of clearance, enough that I was wondering if I might get a 28 in there.
Blog: http://thesetbackpost.com/
PostPosted: Sun Jul 07, 2013 11:48 pm
I've got a Conti GP4000s 25 on a 303 firecrest on the back and there's not much clearance, it might rub if the wheels or tires flex with hard efforts but the wheel is centered in the frame.
PostPosted: Mon Jul 08, 2013 5:20 am
To answer 1 part of this:
DO NOT RIDE IT WITH ANY RUBBING AT ALL!!!
^I'm not sure how to emphasize this enough....absolutely NO RUBBING IS ACCEPTABLE ......at all!!! You WILL (note will, not "may") damage your frame very quickly, and a repair here would be dodgy to say the least. Dish your wheel properly and try again or abandon the idea.
Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
Edit: 2015: darn near won the best South Island series (got second in age
-group)..woo hoo Racy Theremery is back!!
PostPosted: Mon Jul 08, 2013 6:52 am
I've tried it on some Shimano R500 s and also my 2011 Fulcrum Zeros .
Both wheels sit slightly off centre away from drive side and Scott said because of flex from drive side it is normal .
There are no new unread posts for this topic. Scott Foil vs. Addict
DaVinci
29
4583
Wed Mar 01, 2017 6:31 pm
p3dalfaster View the latest post
There are no new unread posts for this topic. Scott Addict feels plush
addictR1
Tue Apr 18, 2017 6:07 pm
addictR1 View the latest post
There are no new unread posts for this topic. Scott Addict SL Tire And Rim Clearance
Beaver
7
956
Thu Jun 22, 2017 10:31 pm
Delorre View the latest post
There are no new unread posts for this topic. Scott Addict SL Frameset Build
Jbarker1975
10
659
Thu Jul 13, 2017 9:14 am
Jbarker1975 View the latest post
There are no new unread posts for this topic. Scott addict 2017 headset
Jbarker1975
Sun Sep 10, 2017 6:06 am
Johnny Rad View the latest post
Users browsing this forum: darnellrm, Google [Bot], maquisard, shiftless, sib and 36 guests
