It is currently Wed May 24, 2017 9:20 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
PostPosted: Sun Jul 07, 2013 6:03 am
After switched to Rotor 3D and Praxis compact from 7950, my chain rubs inside large chainring, I add a 1mm spacer on the drive side, then add another 1mm spacer to the none drive side so I can have Symmetrical Q factor, everything is good, but my crank spindle doesn't stick out long enough, it only go thru 2/3 of the thickness of the none drive side crank arm. What do you guys think, I just don't want the arm come off during riding. The bottom bracket is Enduro Zero Ceramic.
I kinda regret now, should have kept my 7950, it was perfect.
PostPosted: Sun Jul 07, 2013 6:07 am
The preload cap did tread into the spindle with 5-6 turns.
PostPosted: Sun Jul 07, 2013 8:50 am
viewtopic.php?f=3&t=116422
PostPosted: Sun Jul 07, 2013 9:22 am
I wish I saw this post before I sold my 7950, the chainrings I have are the 50/34, wonder if I change to 50/36 will get rid of the rubbing.
PostPosted: Sun Jul 07, 2013 11:42 am
Hi cool,
Why not move the two chain rings ~1mm apart? Use 5 tiny spacers, one at each mounting bolt.
Then remove the axle spacers and enjoy rub-free riding.
Damon Rinard
Engineering Manager, Road Bikes
Cycling Sports Group, Cannondale
Ex-Kestrel, ex-Velomax, ex-Trek, ex-Cervelo
PostPosted: Sun Jul 07, 2013 2:39 pm
http://www.ebikestop.com/chainring_chai ... %29469.php
PostPosted: Sun Jul 07, 2013 5:16 pm
eric wrote:
http://www.ebikestop.com/chainring_chainring_spacers%29%29469.php" onclick="window.open(this.href);return false;
Perfect! Thanks eric. I'd suggest the 0.6 mm spacers first.
http://www.ebikestop.com/06mm_alloy_cha ... CR1229.php
Damon Rinard
PostPosted: Sun Jul 07, 2013 7:32 pm
I am not going to pay $60 buy 5 washers, kinda skeptical, don't even know it will work or not.
The rubbing was the problem, the new problem is in my post title.
I just don't have faith the none drive side crank arm will stay in place, but even if I take out the washer, the Rotor 3D spindle is no gonna go all the way thru to the edge of the NDS arm. Does anyone know how much of the spindle length needs to go into the NDS arm in order to be safe to ride?
PostPosted: Sun Jul 07, 2013 8:55 pm
Buy 5 washers from your LBS. Should cost about $10 or so. They will address your original problem. Then you can undo your bodge job and allow the crank to work correctly.
I would not ride that. Having a crank break is no fun.
PostPosted: Mon Jul 08, 2013 1:44 am
coolmingli wrote:
I am not going to pay $60 buy 5 washers ...
That's $11.95 for a bag of 20 spacers, not the price per spacer. That said, this does not constitute a recommendation as to your course of action.
PostPosted: Wed Jul 10, 2013 2:54 pm
Problem with spacing the rings further apart is that the shifting will suffer and the chain could get stuck in between the rings if the gap is too large.
PostPosted: Wed Jul 10, 2013 6:05 pm
When I added spacers (FSA rings on a Lightning crank), shifting improved. The rings were too close together, which is why I needed the spacers in the first place. There is no standard for the thickness of the spider, or chainring offset, or even the lateral positon of the spider.
I think the OP's new setup suffers from the same problem. He could take some measurements to see if that's actually the case.
PostPosted: Thu Jul 11, 2013 1:56 pm
Different rings, different set-up. the Praxis rings are precisely engineered to ensure shifting is spot-on. Regarding standards, there is a standard for the mid-line of the inter-ring space - 43.5mm.
PostPosted: Thu Jul 11, 2013 6:40 pm
Yea, although I thought it was 45mm to the inner side of the big ring.
But that says nothing about the spacing between the rings, which is what I think the OP's problem is. When the spacing is too narrow the chain rubs on the inside of the big ring. On a 50/34 setup it's already close if not rubbing in the smallest cog. Losing even .5mm there will make a big difference.
PostPosted: Fri Jul 12, 2013 1:14 am
Eric is right on with his advice. The symptoms point directly to the two rings being too close.
Here's a thought: don't buy the Spacers at first. Instead, cut some out of cardboard or thin metal, whatever you have. Give it a try first. If it works (99% sure it will), then buy the real spacers.
Cheers,
Damon Rinard
There are no new unread posts for this topic. Campagnolo C-clip on drive side EPS Ultra Torque cups
58teeth
Fri Jul 01, 2016 11:26 pm
58teeth View the latest post
There are no new unread posts for this topic. Campagnolo Over Torque Left Crankarm fell off
maverick_1
31
2102
Fri Dec 02, 2016 1:15 am
maverick_1 View the latest post
There are no new unread posts for this topic. HELP... Side sizing
upside
Tue Sep 13, 2016 4:20 am
dmp View the latest post
There are no new unread posts for this topic. Campy drive train problems
DeLuz
13
663
Mon May 22, 2017 7:13 pm
2lo8 View the latest post
Users browsing this forum: Bing [Bot], eggleston, Google Adsense [Bot], leej88, maxxevv, Pezeke, Ste_S, Yahoo [Bot] and 41 guests
