BB30 bearing removal Felt F1
missinglink
by missinglink
Hi guys,
I bought an F1 and I'm trying to service the non drive side bearing (BB was creaking like crazy) but this bearing will NOT come out. The drive side was no issue. The bearing does not roll freely. Any recommendations on getting this thing out? I'm using a hand made tool with a 5" bolt with nuts and 1 1/2" washer to spread the load evenly. Any chance that this thing is loctited in place? I bought it 2nd hand
sungod
by sungod
if it has been mounted with loctite, acetone may weaken the bond
it'll flash off fast so try laying the bike on its side and making a 'dam' around the bearing so you can pour it on and let it penetrate
well ventilated area, avoid skin contact etc.
missinglink
by missinglink
Thank you for the ideas, will give it a go.
Mike
gjash
by gjash
I regularly locate in my bb30 bearings and they'll usually pop out after a couple really hard whacks. Bigger hammer?
Sent from my ISW12HT using Tapatalk 4 Beta
seve88
by seve88
It is expensive but the Park tool is obviosuly purpose made and has no risk of marking the frame. If you are sticking with BB30 then it will be worth the investment.
