Converting GXP Quarq to bb30
rheosibal
by rheosibal
So I have done my research but yet to find answers...
I currently own the Sram Elsa Quarq (GXP) 172.5. I now own a cannondale evo which is BB30. I understand there are many ways of putting the GXP crank in a BB30 shell, with uses of adapters such as the MFG adapter. Quarq also offers a service where you send in your GXP crank and they convert it into BB30. I was opting for this option because I prefer BB30 to BB30 without adapters.
Has anyone else sent in their crank to Quarq and has had this service done? Quarq states that when they receive your GXP crank, they remove the quarq spider and give you new crank arms, while attaching a normal spider to your old arms. Does this mean that the quarq spider can be used with both gxp spindles and bb30 spindles? Wouldn't they need to replace the spider too?
Thanks for your help, I'm alittle confused :beerchug:
neevers1
by neevers1
Sounds to me like you will end up with a GXP non powermeter crank and a BB30 powermeter crank.
rheosibal
by rheosibal
quoting above not required
That's their claimed service, but I'm curious as to the powermeter spider. Is the spider universal, meaning can be used regardless of gxp or bb30 crank arms/spindles?
steel515
by steel515
Do you have the phone number or link to this service?
rheosibal
by rheosibal
steel515 wrote:Do you have the phone number or link to this service?
http://www.quarq.com/faq
*4th link from top
I'm guessing the spiders for the Elsa and Riken can be used for both BB30 and GXP spindles/arms.
