It is currently Thu Dec 14, 2017 10:12 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Wed Jul 03, 2013 6:58 pm
I was wondering if I can use these with Boyd clinchers? I believe it's a gigantex(?) rim
I lost the pads that came with the wheelset. They were not that great though but it was of course recommended to use them together. Recently I found these black prince pads which sounds promising. Anyone have some real world experience with them?
PostPosted: Wed Jul 03, 2013 7:59 pm
You can not use the Black Prince with the carbon clinchers, only the pads that were supplied with the rims as they were made by the rim manufacturer (which is not Gigantex by the way). Which model carbon clinchers do you have and how long ago did you get them and the brake pads? The newest carbon clincher brake pads that we have work pretty well. The 2013 models with the Blue Ice brake pads are some of the nicest braking I have even felt on a carbon rim and that is something I hear from a LOT of people.
http://www.boydcycling.com The Handcrafted Revolution
PostPosted: Wed Jul 03, 2013 8:09 pm
It looks like mine was bought August 2011, can I use your latest pads?
PostPosted: Wed Jul 03, 2013 8:16 pm
You can not use the Blue Ice, but you can use the carbon clincher pads for 2012 wheels. It will be a pretty big improvement over the pads you had from 2011.
PostPosted: Wed Jul 03, 2013 8:21 pm
Thanks, maybe losing the old pads was a blessing
I found it ironic you do sell the black prince pads on your site then disclaimer to not use them with your wheels.
PostPosted: Wed Jul 03, 2013 8:32 pm
They work great for the tubulars where it's not as important to have the absolute specific brake pad. On a carbon tubular the heat issue is not as important as there's not outward pressure from the tire pressing against the hook of the rim.
PostPosted: Thu Jul 04, 2013 10:45 am
swissstop black prince pads are good wet and dry hands downs kicks ass on anything else on the market but the wear rate sucks. I am not going lie stick to yellow king they last far longer but if you have alot of cash to splash your bike shop will be loving you constantly buying the pads.
PostPosted: Thu Jul 04, 2013 1:44 pm
I can second that comment on the wear rate.. if you live in a mountainous area and do lots of decents they wont last too long. Brake performance is better than anything else I did run before, but still not good enough on Mavic Ultimates when wet. On the Gigantex 38mm Rims braking is ok when wet and almost to much when dry (85kg bodyweight - Planet X and Campy Brakes).
Supersix HiMod, Supersix EVO HiMod, Crux, CaadX, Lynskey R330 & Pro29, Yelli Screamy 29
PostPosted: Thu Jul 04, 2013 10:00 pm
Yes, but they also get hotter than any other brake pad I've ever seen. Swissstop did their own studies and max temp of the yellow pads was 300degrees Celsius, the Black Prince came in at 170 in the same test.
PostPosted: Sat Jul 06, 2013 3:06 pm
Buy a set of Black and a set of Yellow, use black in front and yellow in the back :)
PostPosted: Sun Jul 07, 2013 6:01 am
I have these.
They are OK, but squeal and wear extremely fast.
PostPosted: Sun Jul 07, 2013 10:44 am
i think the higher wear rate is part of the design - shedding hot pad material during braking keeps the rims cooler
There are no new unread posts for this topic. Campagnolo blue/red pads
Willier
Sat Aug 05, 2017 2:42 pm
Zakalwe View the latest post
There are no new unread posts for this topic. Zipp 303/404, anyone using koolstop pads?
TurboTommy
26
2156
Wed Jul 12, 2017 2:21 pm
dorin View the latest post
There are no new unread posts for this topic. Disc brakes : new pads = brake rub??
Delorre
9
1011
Mon Oct 23, 2017 11:36 am
CBJ View the latest post
There are no new unread posts for this topic. Cycling short pads - your thoughts?
milesthedog
16
1720
Thu Apr 20, 2017 1:26 pm
milesthedog View the latest post
There are no new unread posts for this topic. Brake pads for Lightweight Meilenstein
mike001100
21
1164
Fri Nov 10, 2017 12:01 am
glepore View the latest post
Users browsing this forum: antonioiglesius, Calvaroz, Google Adsense [Bot], kode54, PinaF8, sivan, snowdevlin, TobinHatesYou and 39 guests
