It is currently Thu Oct 19, 2017 1:14 am
PostPosted: Tue Jul 02, 2013 8:31 pm
Needing some new chainrings and there seem to be some deals on the newer SRAM Red rings, (what is the difference between hidden bolt and non-hidden)?
Also this article below states that it is not very easy to simply bolt the new rings on the old crank, but it seems some on this forum have done it.
http://velonews.competitor.com/2012/03/ ... ity_209270
Would the non-hidden bolt chainrings mount on without the difficulty mentioned in the Velonews piece?
Also i've never swapped chainrings, do I need to pull the crank, or can I just un-bolt the old rings?
Thanks for the help.
PostPosted: Wed Jul 03, 2013 6:29 am
I have mounted the non-HB on my quarq S975 without issue, so you'll be right.
It's way easier to remove crank. Have a go, worst you can do is break a chain ring bolt if you doing it by feel!!
PostPosted: Wed Jul 03, 2013 8:32 am
the hidden bolt simply refers to the mounting position on the yaw cranks, on old cranks the bolt isn't hidden
it's not a good idea to put the new rings on old cranks:
i) the anti-jam pin will be in the wrong place, just a cosmetic issue as long as you never have an overshift, if you do then you could end up with the chain stuck hard between crank and ring, possibly damaging something
ii) you have to file down a mounting tab on the small ring to make it fit
with the pre-yaw cranks (no hidden bolt) you can easily swap rings without removing the crankset from the bike
PostPosted: Wed Jul 03, 2013 2:57 pm
So am I understanding properly that the non-hidden bolt rings will be compatible, or is there still an issue with the anti-jam pin? Am I better off with a set of the SRAM Red Black chainrings, or Praxis?
PostPosted: Wed Jul 03, 2013 4:41 pm
any pre-yaw rings will be fine, hidden-bolt is specific to the yaw version
red-black, red-yellow, or original red, all will be perfect on a pre-yaw crankset, the pin will be in the correct position behind the crank arm
PostPosted: Wed Jul 03, 2013 4:53 pm
The whole point of a non-hidden yaw chainring is to fit old cranks.
look at the picture at http://www.artscyclery.com/Sram_Red_Yaw ... 130BN.html
the anti jam pin sits opposite a mounting bolt, so you are fine.
Compare that to: http://www.artscyclery.com/descpage-SRCRY53130B.html, which has the anti jam pin lined up with the hidden mounting bolt.
PostPosted: Wed Jul 03, 2013 5:15 pm
ah, hadn't seen they did a non-hidden version of the yaw ones, that's handy to know
PostPosted: Wed Jul 03, 2013 6:14 pm
I suppose to answer the OP's other question, it depends on what you are trying to achieve.
The Yaw rings shift very well, but are heavy. The old red black rings IMO aren't that great. Praxis shifts almost as well as yaw, but doesn't weigh as much - there's a thread on the exogram cranks that shows the weight differences.
Also, it depends on the ratios, and whether you are going compact or not. 36/52 isn't available for yaw for instance. Compact (assuming a 16T jump between rings) is going to shift worse than standard (39/53), so you might see a bigger difference in overall shifting quality.
If you want the best front shifting, go with Yaw rings on a Yaw derailleur. If you are weight conscious, go with Praxis.
If you are on a budget, with a standard front, old red might be good enough.
There are no new unread posts for this topic. 130 BCD crank w/ 52/36 chainrings?
jbaillie
9
1299
Sat Jan 28, 2017 3:35 pm
mythical View the latest post
There are no new unread posts for this topic. Crank Bearing Puller for SRM Campagnolo Crank
mrgray
14
957
Tue Apr 04, 2017 9:37 am
mrgray View the latest post
There are no new unread posts for this topic. Chainrings
glepore
11
944
Thu Sep 07, 2017 9:29 pm
alastairb View the latest post
There are no new unread posts for this topic. Buying chainrings, need reccomendations
eyedrop
Thu Jan 05, 2017 9:22 pm
ooo View the latest post
There are no new unread posts for this topic. Campag 10S chain with FSA chainrings?
wilwil
Sat Jun 03, 2017 3:32 pm
graeme_f_k View the latest post
Users browsing this forum: 2phat2slow, Baidu [Spider], Bing [Bot], Herb5998, jrobart, kurisu, velomane and 30 guests
