It is currently Tue Jan 23, 2018 7:05 pm
Post new topic  Reply to topic  [ 481 posts ]  Go to page Previous 1 2 3 4 533 Next
PostPosted: Thu Jul 18, 2013 7:12 pm
I, too, am a little confused about how the over-torque cranks are assembled. Hopefully we don't have to use a pin-spanner to tighten everything down.
PostPosted: Thu Jul 18, 2013 8:27 pm
I was about to plump for some 2013 Super Record, do you think the price might drop a bit in the next month or so?
PostPosted: Thu Jul 18, 2013 8:33 pm
The hirth joint is gone for the new version. It's a two piece design. While my Italian isn't great, they do have a line that runs along the theme of why integrate the tools into the crank just to carry extra weight. Having said that I do have pictures of a couple of tools which based just on what I can see, I can't totally see how they are going to work.
As for pricing, I wouldn't expect to see prices drop since none of the existing pieces are being replaced, they are just adding to the line.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Thu Jul 18, 2013 9:34 pm
Great stuff, thanks for clearing that up for me buddy.
PostPosted: Thu Jul 18, 2013 10:09 pm
Sure looks like two fixing bolts and washers in that crank parts explosion.
PostPosted: Fri Jul 19, 2013 1:03 am
The color cut away illustration is the new design.
For reference the poster there added the 2nd picture in B&W which is the Cannondale Hollowgram, and the last picture is an older Campy patent drawing that obviously is not the same as the colored final design.
PostPosted: Fri Jul 19, 2013 1:45 am
Duh, sorry. Now I see "Cannondale" in giant letters...
PostPosted: Fri Jul 19, 2013 1:48 am
So, with the two-piece design and integrated axle in the right crankset, it is most similar to the Power-Torque™ cranksets. In what ways does Over-Torque [ :roll: ] differ from Power-Torque™?
PostPosted: Fri Jul 19, 2013 3:35 am
@ Ritterview
EVO386, BB30 and FPBB30 bikes and cranks/chainrings are very close to flat on the drive side. Power-torque and the "old standards" the crank/chainrings angled back over the cups or the frame. It about the chain line.
C
PostPosted: Fri Jul 19, 2013 6:34 am
So, there are the dimensions on the outside, and mechanical arrangement on the inside. Both are interesting.
How do you reckon the Over-Torque will differ in dimensions and chainline from the Power-Torque?
PostPosted: Fri Jul 19, 2013 2:38 pm
Looks like the light blue collar screws into the purple spindle. That should hold it all together.
PostPosted: Fri Jul 19, 2013 3:13 pm
Tools already available?
http://mikesbikes.com/product/campagnol ... -qc129.htm
PostPosted: Fri Jul 19, 2013 3:25 pm
@ Ritterview
The chain line stays the same, the EVO386, BB30 and FPBB30 bikes the BB part of the frame and 1st 180mm of the chainstay are inline/flat, once the chainstay passes the chain ring then it widens. sorry I couldn't find a good pix.
PostPosted: Fri Jul 19, 2013 4:56 pm
last month we installed a power-torque crankset on my Dad's new bike. I'm still not sure how we are going to get that thing off. Dad's response was "that nut should have a threaded cover so that it self extracts, like the old cranks!" I agree . . .
PostPosted: Fri Jul 19, 2013 6:35 pm
The answer is simple. You buy a crankarm/ bearing puller. campy sells some protectors that you put behind the crank arm so that you don`t scratch the crank arm. You can easily make them yourself with some cardboard.
http://velonews.competitor.com/2013/04/bikes-and-tech/how-to-remove-campagnolo-power-torque-cranks_280400
There are no new unread posts for this topic. Campagnolo vs Shimano vs SRAM Hydro-Electric-Disc groups
jever98
19
2764
Wed Jun 14, 2017 1:29 pm
Miller View the latest post
There are no new unread posts for this topic. Tarmac Pro SL4 2014
tarmacdz
Sun Jun 11, 2017 6:54 pm
tarmacdz View the latest post
There are no new unread posts for this topic. Domane 2.3 2014
kordis1
Mon Oct 30, 2017 10:38 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo 11 speed using 34/50x11/36! Yes it can be done with PRE-2015 Athena LC Big Gears on Campagnolo 11 speed
colnagoaddict
16
1566
Mon Dec 18, 2017 8:49 pm
graeme_f_k View the latest post
There are no new unread posts for this topic. 2014 Addict Team Edition HMX
jzinckgra
9
736
Sun Nov 19, 2017 1:23 am
jzinckgra View the latest post
Users browsing this forum: BdaGhisallo, Bing [Bot], bremerradkurier, Hexsense, jever98, Malammik, RussellS, userfriendly, vinuneuro, wingguy, zefs and 32 guests
