It is currently Fri Jan 19, 2018 8:53 pm
Post new topic  Reply to topic  [ 481 posts ]  Go to page Previous 17 8 9 10 1133 Next
PostPosted: Tue Oct 22, 2013 6:13 am
On another note, something that has always bothered me is the small-ish hex-bolts used to clamp the shifters to the bar or to mount the brakeset to the frame. Why can't they use larger bolts like Shimano? those are pretty tough and can withstand pretty much any amount of torque you can produce with your bare hands and a small hex bit.
PostPosted: Tue Oct 22, 2013 6:15 am
Tinker, Taylor, Tart
You can easily change them...
 Post subject:
PostPosted: Tue Oct 22, 2013 6:24 am
PostPosted: Tue Oct 22, 2013 6:35 am
Yes, but Ti hardware costs quite a bit..
 Post subject: Re:
PostPosted: Tue Oct 22, 2013 6:37 am
Causidicus wrote:
What's wrong with the T25 Torx that Campagnolo uses now? Handles far more torque than 5mm hex.
No it doesn't.
 Post subject:
PostPosted: Tue Oct 22, 2013 6:52 am
PostPosted: Tue Oct 22, 2013 8:53 am
Shop Owner / Manufacturer
With both the a/k and the Torx bolt, there's no real issue if a long key rather than the folding type is used and the head is aligned to the bolt. Both are specced considerably above the required torque to hold the lever to the bar, so long as the bar shape and diameter are to spec.
If you need to exceed the quoted torque on either bolt to secure the lever, the chances are, something is off somewhere.
We get levers in for service from time to time where the clamp end of the bolt is slightly belled where it has been overtightened against the clamp - that takes quite a bit of compression and a torque way beyond the rated torque of the bolt.
GFK, Velotech Cycling Ltd, Campanolog Main SC, UK
PostPosted: Fri Nov 01, 2013 5:12 am
When are the internal battery and V2 interface going to be available?
PostPosted: Fri Nov 01, 2013 7:47 am
I have been told end of September (came and went), mid October (came and went), end of October (came and went) and now November/December.
I phoned Campagnolo directly and was told that production is well underway, and it has already started to ship out. Unfortunately they couldn't tell me where to, and I can't track any down.
HiBike.de listed it as available, so I ordered some there. They had the battery, no extension cables, and then cancelled the charger that i had ordered (what good is one without the other?!). I managed to find the installation tool, but nothing else.
I have a bike build sitting semi-finished waiting for the internal battery (it hasn't been built with an external wiring option) and it is driving me crazy!
I am sure it will be worth the wait. Can't be long now I guess.
PostPosted: Fri Nov 01, 2013 12:02 pm
Campag seem really slack at actually shipping stuff lately, they announced the Bora 35 back in may..... still can't find anyone that actually has them for salele. in stock
PostPosted: Fri Nov 01, 2013 1:02 pm
Which version are you after? Bora One or Ultra? Dark or standard graphics?
PostPosted: Fri Nov 01, 2013 3:05 pm
wasn"t looking for anything in particular...... it was an observation.
PostPosted: Fri Nov 01, 2013 3:08 pm
The EPS V2 battery, interface unit and charger are available as we've already got stock on them. The new cranks on the other hand won't be available before late December.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Fri Nov 01, 2013 4:55 pm
We have Bora One 35 Dark & Ultra Standard in stock. Also most of the Overtorque cranks in 172.5 and bb30 cups.
PostPosted: Wed Nov 06, 2013 8:49 pm
So what are they all like? Got pics and real full weights and stuff?
2012 BMC SLR 6.02kg http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=110390
There are no new unread posts for this topic. Campagnolo vs Shimano vs SRAM Hydro-Electric-Disc groups
jever98
19
2722
Wed Jun 14, 2017 1:29 pm
Miller View the latest post
There are no new unread posts for this topic. Tarmac Pro SL4 2014
tarmacdz
Sun Jun 11, 2017 6:54 pm
tarmacdz View the latest post
There are no new unread posts for this topic. Domane 2.3 2014
kordis1
Mon Oct 30, 2017 10:38 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo 11 speed using 34/50x11/36! Yes it can be done with PRE-2015 Athena LC Big Gears on Campagnolo 11 speed
colnagoaddict
16
1530
Mon Dec 18, 2017 8:49 pm
graeme_f_k View the latest post
There are no new unread posts for this topic. 2014 Addict Team Edition HMX
jzinckgra
9
711
Sun Nov 19, 2017 1:23 am
jzinckgra View the latest post
Users browsing this forum: Cervelolite, darnellrm, DeRibble, Google [Bot], gospastic, joeg26er, lovinmylab, rasmusic, RussellS and 59 guests
