It is currently Sun Oct 22, 2017 2:55 pm
Post new topic  Reply to topic  [ 152 posts ]  Go to page 1 2 3 4 511 Next
 Post subject: 2014 Scott Addict SL
PostPosted: Sat Jun 29, 2013 3:11 pm
Anyone know more details about the new Scott Addict SL?
http://www.bikerumor.com/2013/06/28/sco ... ct-sl-yet/
Video is long and mostly uninformative...
Wondering about price and weights.
 Post subject: Re: 2014 Scott Addict SL
PostPosted: Sat Jun 29, 2013 4:40 pm
There was a claim on Bikeradar that the frame & fork is bellow 1kg combined, which is quite impressive if true. However, not as light as I would have hoped... Given that a decent fork weighs what, 300g? It doesn't make for an insanely light frame.
Here is the Bikeradar article, it also includes some claimed weights for the models other than the top one:
http://www.bikeradar.com/road/news/arti ... kes-37751/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Edit: The article seems to have been updated - Frame weight for a 55cm was 741g, for 278g with an uncut steerer.
Cost for the top of the line model is 8000 Euros.
PostPosted: Sat Jun 29, 2013 5:25 pm
Nothing special. That weight is higher than the lightest Evo and much higher than an RCA. Hell, it's higher than the R5CA
PostPosted: Sat Jun 29, 2013 6:14 pm
1 kg frame + fork is extremely light for a mass-volume production frame. I wouldn't count the Cervelo RCa: it's $10k frame + fork alone and only 300 are available (AFAIK). It's almost certainly lighter than the Evo.
There's a nicely done video here.
Interesting is they make a claim in wind resistance. I thought the Addict was in the fatty-tube category: wind be damned.
Photos appear to have a truncated airfoil profile to the down tube, similar to a Foil, so perhaps that's it.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Sat Jun 29, 2013 6:34 pm
scott claims 25% lower drag than previous addict. should equal the cervelo/madone on aero drag. the weight is impressive. ww need to remember
rca is built around proprietary BBright. when you run heavy rotor adapter the rca is over 700gm. the addict fork is lighter than the rca.
e.g
shimano press fit bb86 weighs 65gm vs 137 for rotor 24 adapter.....memo to cervelo dump the bbright and go with shimano bb86 or bb386.
http://www.rotorbike.com/products/road/ ... t-frame_43
PRESS FIT 4624 for BBRIGHT frames
Acero (negro) 137g,
Cerámico (rojo) 128g.
Aluminio anodizado, grabado láser.
Mecanizado en torno CNC con AL 7075 T6 tratado.
Sellos de silicona y tubo interno (menor contaminación, menos mantenimiento).
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
PostPosted: Sat Jun 29, 2013 6:41 pm
Love my 2010 Addict, but I work for a Scott dealer and this could be very tempting.
Blog: http://thesetbackpost.com/
PostPosted: Sat Jun 29, 2013 8:56 pm
Someone pop on it!
Report back ASAP.
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Sat Jun 29, 2013 8:59 pm
As far as adverts go, Scott nailed it with that one. It's terrific.
Very nice looking machine too! Can see there being a lot of them on here soon.
The Gram
The Men of Steel
PostPosted: Sat Jun 29, 2013 10:08 pm
Carbon Cowboy
djconnel wrote:
1 kg frame + fork is extremely light for a mass-volume production frame. I wouldn't count the Cervelo RCa: it's $10k frame + fork alone and only 300 are available (AFAIK). .../
+1
(and the frameset might be around 1/3 of the RCa price)
Berk PROTO-TYPE Composites - Handmade In Slovenia
Berk Composites
http://www.berk-composites.com/
info(a)berk-composites.com
PostPosted: Sun Jun 30, 2013 12:57 am
Looks very nice.Would be a good replacement for my aging Gios Carbon V107 :)
PostPosted: Sun Jun 30, 2013 4:01 am
e.g
http://www.rotorbike.com/products/road/ ... t-frame_43" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Acero (negro) 137g,
Or you could just get THM BBright bottom bracket at 91 grams. The Cervelo's weight includes hardware such as front and rear derailleur hangers, all bottle cage bolts, the grommets for the cable routing, and the seatpost clamp.
In other words, the frame alone is in the 620 grams range. Even with the weight added by the THM BB, it's still about 100 grams lighter than the Addict. I'm not sure how much lighter the Addict fork is than the Cervelo fork. The whole steerer tube of the RCA is covered with the Nanovate coating so it is likely that it will lose more weight in cutting the steerer than the Scott. Maybe 20 grams heavier in the end, depends on how much steerer these forks are measured with. The RCA also includes an integrated magnet. I don't think the Addict has that.
Yes the RCA is considered a "limited" production frame. But if it is valid for the Protour, it is certainly the valid benchmark.
PostPosted: Sun Jun 30, 2013 6:21 am
This is getting a bit ridiculous. Is there a white paper on the steer tube coating and comparative densities? Let it go.
PostPosted: Sun Jun 30, 2013 7:36 am
djconnel wrote:
1 kg frame + fork is extremely light for a mass-volume production frame. .... It's almost certainly lighter than the Evo.
Very good point, most people keep pushing the corrected weight numbers for the EVO when almost no-one has had a frame come in anywhere near those claims.
PostPosted: Sun Jun 30, 2013 7:41 am
coating vs no coating adds weight. Pretty simple, given that Cervelo has shown that they can make sub 300 gram uncut forks easily.
PostPosted: Sun Jun 30, 2013 10:18 am
The Cervelo RCa fork we have here weighed in at 300g ++ uncut *. It looks remarkably like a 3T Rigida fork with some small differences apart from the coating. The Rigida LTD weighs 275g on the same scale btwy. The old Ca fork was well south of 300g and made by THM in Germany.
Quite normal practice in the industry to show pre production units to the press to establish a weight that then becomes the norm in the blogs, forums etc......
Sorry for off topic but credit where credit's due!
* the corresponding frame, a 56, is 677g plus der hanger and hardware (fd included).
Sent from my iPad using Tapatalk HD
rolobikes
There are no new unread posts for this topic. Scott Foil vs. Addict
DaVinci
29
5086
Wed Mar 01, 2017 6:31 pm
p3dalfaster View the latest post
There are no new unread posts for this topic. Scott Addict SL Tire And Rim Clearance
Beaver
7
1064
Thu Jun 22, 2017 10:31 pm
Delorre View the latest post
There are no new unread posts for this topic. Scott Addict feels plush
addictR1
Tue Apr 18, 2017 6:07 pm
addictR1 View the latest post
There are no new unread posts for this topic. Scott Addict SL Frameset Build
Jbarker1975
10
744
Thu Jul 13, 2017 9:14 am
Jbarker1975 View the latest post
There are no new unread posts for this topic. Scott addict 2017 headset
Jbarker1975
Sun Sep 10, 2017 6:06 am
Johnny Rad View the latest post
Users browsing this forum: 964Cup, Baidu [Spider], Bing [Bot], Delorre, dim, Google [Bot], Google Adsense [Bot], jwfinesse, RedbullFiXX, simplemind, themidge and 36 guests
