It is currently Thu Dec 14, 2017 12:08 am
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Wed Jun 26, 2013 11:32 pm
We are talking Stronglight Fission ActivLink ...
http://www.stronglight.com/stronglight/ ... onTItriple" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
which is not that different from GigaXPipe ...
http://www.parktool.com/uploads/images/ ... ativ_3.jpg" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
The splines are standard ISIS ones, and after a recent check the crank arms no longer align. Misalignment is of the order of a few mm and is easily noticable. And no, it is not simply the case that the splines are interlocked wrong.
And thoughts you kind people?
PostPosted: Wed Jun 26, 2013 11:42 pm
Sounds like your spindle yielded.
PostPosted: Wed Jun 26, 2013 11:55 pm
Baffled. No sign of any yielding or defect. Both the cap with the holes for the pin spanner on the DS and the same on the NDS are securely bonded into the crank arms, and the axle seems securely threaded and bionded into the DS crank.
Had it for over a year. Surely I would have noticed if it came out of the box like this.
PostPosted: Thu Jun 27, 2013 2:49 pm
With cranks horizontal, stomp down on both sides at the same time; then rotate 180° and try again. Do you feel (or see) any motion ?
When my EC90 cranks' spindle debonded from the spider this is how it was most obvious.
Easton gve me a full refund even after a year of use. I don't know about Stronglight.
There are no new unread posts for this topic. Larger pulleys longer chain?
desperado95219
Sun May 14, 2017 8:45 am
mattr View the latest post
There are no new unread posts for this topic. Shorter crank experiences. Then back to longer ones!
xcnick
Wed Dec 13, 2017 11:03 pm
Mr.Gib View the latest post
There are no new unread posts for this topic. Weight of SRAM CX1/S900 GXP arms?
hmai18
Wed Dec 28, 2016 3:58 am
hmai18 View the latest post
There are no new unread posts for this topic. Attachment(s) New SISL2 crank arms - Is this a defect or normal?
glowder
Wed Dec 06, 2017 11:55 pm
Jenmoss View the latest post
There are no new unread posts for this topic. Attachment(s) spider for k-force light crank arms other than power2max?
lovemyway
Fri Feb 10, 2017 7:56 pm
lovemyway View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot], vanillaflyweight and 32 guests
