It is currently Fri Mar 24, 2017 11:38 am
PostPosted: Sat Jun 22, 2013 1:54 am
I've got three of these - each one different. I would be grateful if someone could tell me if there were any others. I don't think so.
PostPosted: Sat Jun 22, 2013 2:34 am
5.5 mm hex is for current Bora, etc wheels.
PostPosted: Sat Jun 22, 2013 3:13 am
sorry but I boght a 5,5 mm tool,but actualy it's a 5 mm tool require to the inner niples.
cycling,a great individual sport,were you can't reach anything,whithout group effort.
PostPosted: Sat Jun 22, 2013 3:40 am
So your reply had me curious - as I had called Campagnolo USA to get to the bottom of the issue. They reassured me that 5.5 was correct for current generation Bora's - so I bought such a wrench.....but never tested it.........until tonight.
My new 5.5 doesn't work..... :evil: .
The good thing in all this is those wheels are so damn robust that truing them isn't something I'm needing to do anytime soon!! :thumbup:
PostPosted: Sat Jun 22, 2013 12:01 pm
sorry about that.I also have one 5,5.
all literature about the campy wrench say 5,5mm,I dont know where they took that number.maybe from they wrench on the outer mesure.who knows.
luckly you won't need any time soon to use the wrench.
PostPosted: Sat Jun 22, 2013 1:45 pm
Unless someone knows different, there have been three Campgnolo deep rim nipple tools:-
UT-HU070 - Look down the end of this tool and you will find a 5.5mm female hex pattern. For early Shamal, Vento and Zonda wheels up to 1998. I used my tool on the early Shamals.
From 1991, Campag deep section wheels (not including Bora) switched to 5.0mm female hex pattern, and Campag did not make a special tool because such things are widely available.
UT-HU060 Version 1: Look down the end and you will find a four sided/square 3.2mm female pattern for Bora wheels.
UT-HU060 Version 2: Look down the end and it will be cylindrical, with four flutes. Sized at 3.2mm and does the same thing as the Bora tool above.
PostPosted: Sat Jun 22, 2013 11:52 pm
Tubbie Guru
Hi,
There's a Y shaped key from Park Tool that should allow you to service all Campa wheels.
Service being the wrong word, Campa wheels don't need servicing other than free hubs and bearings... Or, do they?
Cheers, :)
PostPosted: Sun Jun 23, 2013 3:58 am
The wrench is only required in the carbon hubs to change the bearings cups.
There are no new unread posts for this topic. Campagnolo EPS wireless on the way?
Mockenrue
Sat Dec 10, 2016 10:59 pm
MyM3Coupe View the latest post
There are no new unread posts for this topic. Can't charge campagnolo EPS
JBNX
Sun Jun 12, 2016 7:05 pm
cyclespeed View the latest post
There are no new unread posts for this topic. From Shimano to Campagnolo, what does mix
Alumen
Mon Aug 22, 2016 8:39 pm
topflightpro View the latest post
There are no new unread posts for this topic. Campagnolo EPS issue?
pritchet74
7
784
Sat Apr 16, 2016 4:44 pm
audiojan View the latest post
There are no new unread posts for this topic. Campagnolo EPS compatibility
pritchet74
18
1785
Sat Jan 28, 2017 3:05 am
Valienteboy View the latest post
Users browsing this forum: Baidu [Spider], BdaGhisallo, Kumppa, MattSoutherden, Rudi, silvalis, sungod, Zakalwe and 18 guests
