It is currently Mon Jan 22, 2018 5:42 am
Post new topic  Reply to topic  [ 318 posts ]  Go to page Previous 1 2 3 4 5 622 Next
PostPosted: Mon Feb 17, 2014 10:45 am
Administrator
Its in this thread but here it is again. 40mm.
RESIDENT GRUMPY OLD MAN.
PostPosted: Tue Feb 18, 2014 3:48 pm
Just got mine, can confirm that the stack height is 40mm, weight came in at 102.4g as well. I'll probably end up tuning with Ti bolts and taking some acetone to logos, but initial impressions are positive!
PostPosted: Tue Feb 18, 2014 3:53 pm
What length is your stem?
6.24kg CAAD10
PostPosted: Tue Feb 18, 2014 8:51 pm
I can´t seem to find them with 17/73 degrees on ebay. Does anyone know, if they offer that option?
PostPosted: Tue Feb 18, 2014 9:33 pm
Do Kalloy make some kind of light seatpost to match the stem?
Custom Rychtarski steel bike
Ridley X-ride 10
Custom Wittson Ti
PostPosted: Tue Feb 18, 2014 9:48 pm
Oops should have included that, 100mm stem. I've only seen this stem in the 7 degree rise.
Doesn't look like there's a matching seatpost (from the quick search that I did on ebay). There's an "Uno" model but it seems like a pretty standard heavy alloy seatpost.
PostPosted: Wed Feb 19, 2014 11:00 am
Anyone know if the clamp is designed to be fully closed on one side so that the gap only remains on the other side? Or do I have to even out the gaps?
Couldn't find anything on the website.
PostPosted: Sun Feb 23, 2014 5:35 am
I purchased one of these in 60mm for my 29er from joeyangair on fleabags. It came in a simple plastic bag with Kalloy mini manual attached via a sparkly string. Anyways, in the instructions it specifically tells you to tighten the top two bolts fully to mesh with the stem body. The face plate and body have shaped portions designed to mesh with each other. Honestly, the quality appears top knock with very precise forging throughout with constantly varying wall thickness. Reading the included literature it looks as if they've done their homework. I'm really not surprised as Kalloy have been in the business for a long time and clearly have lots of experience. Best deal on stems out there. Just glad I stumbled upon them.
PostPosted: Thu Feb 27, 2014 8:10 am
Cool, thanks for the confirmation - I thought I had seen that info somewhere.
BTW, I also removed the graphics on mine, wiped right off with acetone, 3 minute job.
PostPosted: Thu Feb 27, 2014 8:32 am
Found it, the link on the Kalloy page was broken:
PostPosted: Mon Mar 03, 2014 10:22 am
I'm still waiting for one :-) again :-P
PostPosted: Mon Mar 24, 2014 11:48 pm
I'm considering one of these stems but it's for a TT bike and the stem would be clamping a set of aerobars with extensions. How secure is the handlebar clamp on this Kalloy stem? It needs to be very secure and I am unconvinced by the Kalloy's two part faceplate design.
PostPosted: Tue Mar 25, 2014 3:49 pm
I used carbon friction paste on the bars and clamping is very secure already at low torque.
PostPosted: Fri Mar 28, 2014 3:46 am
Have a 110 on the way. Too bad there aren't any -17 but oh well.
PostPosted: Fri Mar 28, 2014 4:28 am
I have the same stem... Its very rock solid.. No flex... Maybe I should swap out the bolts to Ti
Sent from my cm_tenderloin using Tapatalk
There are no new unread posts for this topic. Attachment(s) My fist prototype product Ultralight CF saddle-->59grams :) UPDATE VERSION 2.0
bikemaniack
31
3992
Sat Jul 08, 2017 9:23 pm
jobvisser View the latest post
Users browsing this forum: Baidu [Spider], kookie and 46 guests
