Kalloy Uno Ultralight.
moshinho
by moshinho
I'm waiting for one too...again!
Marin
by Marin
Here's my 110mm Uno 7 from seller bi_king:
It's going on my open mould build here.
drainyoo
by drainyoo
Juanmoretime wrote:Missed this. They did have a longer date but delivered quick. Also it is Chinese new Year which will slow things down right now.
Thanks.
Marin wrote:Here's my 110mm Uno 7 from seller bi_king:
How long did it take for it to arrive?
Marin
by Marin
Under 2 weeks to Austria
jason9020
by jason9020
I was thinking of going for an ibis stem, but I'm unsure of the stack height on it. I need one with a lower stack than my fsa one that I have on now.
jason9020
by jason9020
Anyone know the stack height on these stems?
Ragamuffin
by Ragamuffin
Just got mine, can confirm that the stack height is 40mm, weight came in at 102.4g as well. I'll probably end up tuning with Ti bolts and taking some acetone to logos, but initial impressions are positive!
drainyoo
by drainyoo
What length is your stem?
Slagter
by Slagter
I can´t seem to find them with 17/73 degrees on ebay. Does anyone know, if they offer that option?
Elrey
by Elrey
Do Kalloy make some kind of light seatpost to match the stem?
Ragamuffin
by Ragamuffin
Oops should have included that, 100mm stem. I've only seen this stem in the 7 degree rise.
Doesn't look like there's a matching seatpost (from the quick search that I did on ebay). There's an "Uno" model but it seems like a pretty standard heavy alloy seatpost.
Marin
by Marin
Anyone know if the clamp is designed to be fully closed on one side so that the gap only remains on the other side? Or do I have to even out the gaps?
Couldn't find anything on the website.
Lumberjake
by Lumberjake
I purchased one of these in 60mm for my 29er from joeyangair on fleabags. It came in a simple plastic bag with Kalloy mini manual attached via a sparkly string. Anyways, in the instructions it specifically tells you to tighten the top two bolts fully to mesh with the stem body. The face plate and body have shaped portions designed to mesh with each other. Honestly, the quality appears top knock with very precise forging throughout with constantly varying wall thickness. Reading the included literature it looks as if they've done their homework. I'm really not surprised as Kalloy have been in the business for a long time and clearly have lots of experience. Best deal on stems out there. Just glad I stumbled upon them.
Marin
by Marin
Cool, thanks for the confirmation - I thought I had seen that info somewhere.
BTW, I also removed the graphics on mine, wiped right off with acetone, 3 minute job.
Marin
by Marin
Found it, the link on the Kalloy page was broken:
