P90Puma
by P90Puma on Mon Aug 28, 2017 8:24 pm
stevec1975 wrote:mrlobber wrote:Anyone ever mounted an out-front Garmin mount on an Uno stem (Tillquist, Fetha etc)? If yes, could you confirm, what's the distance between the faceplate bolts - 24 or 25mm?
I am looking at this as well, so this mount
http://edge-mount.bike/?product=mount-24 should work right, anyone got this installed?
Ditto, anyone do this? Just got the 120mm -17 and it came in at 119g with stock bolts.
addictR1
by addictR1 on Fri Sep 01, 2017 4:05 am
Just picked up my 4th Uno Kalloy stem. I love it! Picked up gold Ti screw using my eBay buck. Pretty light for a 90mm 17degree.
MichaelB
by MichaelB on Tue Sep 19, 2017 11:52 pm
Can anyone do me a huge favour ?
Can someone please measure the horizontal faceplate bolt spacing ? Need to compare it to an older 3T ARX stem to see if my current Garmin mount will still fit ?
Many thanks
Krackor
P90Puma
by P90Puma on Wed Mar 07, 2018 10:10 pm
stevec1975 wrote: ↑Wed Apr 19, 2017 4:53 pm
Echoing this, as can't seem to find a straight answer. Should work as the spacing is correct but haven't seen anyone run this?
