It is currently Fri Jan 19, 2018 2:31 pm
Post new topic  Reply to topic  [ 318 posts ]  Go to page 1 2 3 4 522 Next
 Post subject: Kalloy Uno Ultralight.
PostPosted: Tue Jun 18, 2013 1:06 am
Administrator
I needed a different angle for a stem to put on my fixie. So I purchased this for the sum $22.65 shipped from a certain website that begins with E. Advertised at 116 grams.
The finish is very good and it felt stiff enough on a short ride.
Then adding titanium bolts and washers from Toronto cycles more than doubled what I had into it. So for a grand total of $47.15 this is what you get:
Not bad for a budget build.
RESIDENT GRUMPY OLD MAN.
PostPosted: Tue Jun 18, 2013 1:30 am
:thumbup:
I bought short ones for my daughter's builds and they're below 100 g :shock: !!!
Louis :)
PostPosted: Tue Jun 18, 2013 3:05 am
Administrator
I suppose I should add that it is 100mm.
PostPosted: Tue Jun 18, 2013 6:30 am
Great budget weenie item there ! :thumbup:
They look like 6 or 7 degree stems ?
PostPosted: Tue Jun 18, 2013 8:44 am
It's 7 degrees!
PostPosted: Tue Jun 18, 2013 12:41 pm
What spec. are the bolts on these stems please? M5, M6?
> '13 Supersix Evo Red 5.98kg
> '17 CAAD12 Disc 8.16kg
@ste_dot
PostPosted: Tue Jun 18, 2013 2:15 pm
Administrator
Bolts are M5 X 18mm. Toronto has bolts with the small washers installed.
PostPosted: Tue Jun 18, 2013 4:35 pm
Many thanks.
@ste_dot
PostPosted: Tue Jun 18, 2013 5:08 pm
I am thinking of getting one of these for my 29er with a wider bar. I really like the weight/price on these stems. Accetone the stem and ti bolts and you have a winner.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
PostPosted: Tue Jun 18, 2013 9:39 pm
There's quite a few different models on ebay, I was quite confused when ordering but ended up with the Kalloy Uno Nine: http://www.ebay.com/itm/NEW-2013-KALLOY ... 1065108370?
Hasn't arrived yet, but will definitely be taking the acetone to it!
PostPosted: Tue Jun 18, 2013 10:12 pm
Do you even need the ti washers? Dump them and less weight
2012 BMC SLR 6.02kg http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=110390
PostPosted: Wed Jun 19, 2013 9:12 am
From looking at loads of listings, the 7 seems to be the lightest - the 9 is listed for MTB as well as road, so I assume it's slightly stronger? 6 and 7 seem to be for road, with 7 being a higher grade / lighter alloy. I ordered a 7.
Chances are they're identical with different graphics though. :D
I'll be hitting mine with the acetone and have ordered some Ti bolts too, will weigh it once it's here.
@ste_dot
PostPosted: Wed Jun 19, 2013 10:20 pm
Well it arrived today! 10 days from Taiwan to the UK.
The 'nine' I bought is in fact a 'six' according to the graphics. But I'm not complaining, weight is only 3g over. It's a 90mm.
PostPosted: Thu Jun 20, 2013 12:47 pm
Great, is that with the supplied bolts?
@ste_dot
PostPosted: Thu Jun 20, 2013 2:16 pm
Yup
There are no new unread posts for this topic. Attachment(s) My fist prototype product Ultralight CF saddle-->59grams :) UPDATE VERSION 2.0
bikemaniack
31
3971
Sat Jul 08, 2017 9:23 pm
jobvisser View the latest post
Users browsing this forum: benjaminm3, Bing [Bot], jacobeh, jb, rajMAN and 45 guests
cron
