It is currently Fri Jan 19, 2018 8:59 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Tue Jun 25, 2013 8:36 pm
Lewis wrote:
@ stella-azzurra - I bought a tool to keep those in place whilst tightening the bolts. Also they are torqued to 8NM as recommended by Campag.
I cleaned the bike properly before a long ride sunday and couldn't see any other areas that would cause a creak. It's definitely coming from the crank area and is the same noise as before. Can't think what else it would be. Pedals are tight, no movement in the cranks from left to right (so not loose), no frame cracks that I can see....
I assume you checked the bottom bracket. How about the cleats on your shoes. Those can creak as well when they wear out.
PostPosted: Wed Jun 26, 2013 2:44 am
If its really the chainring bolts, use anti-seize copper grease. Not on the threads, but on the interface that surrounds the bolts. The surfaces it contacts with the rings, the chainrings contact surfaces with the crank arms.
It will eliminate the sound. I had that issue a long time ago on some low end cranksets that didn't have the best tolerances. Irritated the hell out of me, did the above, and the creaking was done with.
PostPosted: Fri Jun 28, 2013 2:11 pm
I guess an upgrade to record would make it go away! :P Saying that, Athena isn't really budget so it shouldn't creak at all! :x
I think your point regarding the contact surfaces is a good one. I may dissaemble it all, get new bolts then do what you suggested.
Stella - I have check the pedals and they seem OK. The noise is the same type of 'fragile sounding crack' that I had previously when the CR bolts had worked loose, which is why I am certain it's the same issue. It's a very recognizable high pitched cricking sound lijke a paper clip hitting on a frame for example.
2012 Canyon Ultimate AL 8.0
PostPosted: Fri Jun 28, 2013 4:38 pm
I did not say to check the pedals I said the cleats on your shoes could be worn out causing a creaking noise.
Also be sure the crank arm is not hitting your front derailleur as it passes when in the big chain ring.
PostPosted: Tue Jul 02, 2013 2:12 pm
Ok will do, thanks for your advice once again :thumbup:
There are no new unread posts for this topic. Attachment(s) Campagnolo 11 speed using 34/50x11/36! Yes it can be done with PRE-2015 Athena LC Big Gears on Campagnolo 11 speed
colnagoaddict
16
1511
Mon Dec 18, 2017 8:49 pm
graeme_f_k View the latest post
There are no new unread posts for this topic. Campagnolo compatibility 10s veloce rd - 11s athena shifters
silvalis
11
1047
Tue Jun 06, 2017 5:11 am
silvalis View the latest post
There are no new unread posts for this topic. Campagnolo Athena 11 Speed Triple LH Lever as a Double?
Mon Mar 13, 2017 4:13 pm
5 8 5 View the latest post
There are no new unread posts for this topic. Campagnolo 53 and 36 chainring combo ?
nismosr
Sat Nov 04, 2017 2:53 am
Squashednuts View the latest post
There are no new unread posts for this topic. campagnolo centaur 11 speed chainring compatibility
JoO
Sun Oct 22, 2017 3:19 pm
JoO View the latest post
Users browsing this forum: Baidu [Spider], cyclenutnz, kgt, kyleFu, nlop, PinaF8, slake21 and 25 guests
