SRAM Red 22 weights
Sacke
by Sacke
I don't know if this has been posted yet, but the weights for the new SRAM Red 22 group are as follows.
Cranks, compact, 175mm: 576g
Cassette 11-25: 160g
Shifters, including cables: 312g
Rear derailleur: 144g
Front derrailleur: 74g
Brakes, including brakepads: 254g
Bottom bracket: 112g
Total: 1632g, without the chain.
I'll post pictures of components on the scale, once I get them transferred to the computer.
madcow
by madcow
Thanks for sharing. We also spent some time this morning weighing and cataloging Red22 along with Force22 so we could update our complete group listings. These are listings that include everything, cables and housings, wires, batteries etc... Apples to apples comparisons.
Your weights look very close to the weights we found on the Red22 stuff.
In case you're interested here are the complete group weights including some of the newer shimano ones as well.
http://fairwheelbikes.com/c/forums/topi ... p-weights/
wolfesquire
by wolfesquire
Can't wait till you have the complete weights for Ui2 11 speed and Force22. Been wanting a new groupset very soon...
rmerka
by rmerka
I would have thought 9070 Di2 would have been heavier than the mechanical 9000. Also they've obviously done something more to Red 22 than just add an extra gear. That's surprising to me. Thank you.
madcow
by madcow
wolfesquire, I can tell you that Force22 is 2065.2 grams for everything except the cassette. Once I have the cassette I'll update the full listings.
ultimobici
by ultimobici
What isa this Ui2 I keep seeing mention? :noidea:
Digital Integrated Intelligence, FFS.
5 8 5
by 5 8 5
madcow, thanks for the weights.
Did the Campag SR groupset weighed have the Ti UT spindle and was the rear brake single pivot, basically the lightest possible options.
madcow
by madcow
Yes, the crank was ti spindle and the brakes were the single pivot rear (272 grams per pair.) Those two same pieces were used in the SR EPS group as well.
spartan
by spartan
excellent work gentlemen.
looking at madcow's data 9070 di2 drivetrain(no crankset/brakes) will be very close to sram red 22. less the 50gm.
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
