It is currently Wed Feb 22, 2017 5:33 am
Post new topic  Reply to topic  [ 4 posts ]
 Post subject: Zipp Stem and Topcap
PostPosted: Mon Jun 10, 2013 5:30 pm
Hello all,
I can use some help. I just installed a Zipp cockpit (SL145 and CSL bar) on my CAAD10 (w/105's). The stem came with a top cap but no bolt. I was wondering if anyone else faced this problem. the FSA expander that was provided with the bike's bolt is not long enough so I can't just put it on there. IS there a good extender to put this cap on or is there something else I should do?
thanks
zuck
 Post subject: Re: Zipp Stem and Topcap
PostPosted: Tue Jun 11, 2013 2:01 am
It sounds like the expander is too low in the steerer... the 145's stack height isn't really huge so I would probably move the expander up so the bolt will thread in.
 Post subject:
PostPosted: Tue Jun 11, 2013 12:35 pm
You can't use the Zipp top cap with your current setup. You have the Cannondale SI expander/compression plug that is intended to support the inner wall of the steerer.
I recommend sticking with the factory setup, although one could conceivably use a different type of compression plug. The Specialized type supports the inner wall of the steerer well and allows for any top cap. There is a small lip at the top of those so an extra 2.5mm spacer may be necessary.
Sent from my EVO using Tapatalk 4 Beta
PostPosted: Tue Jun 11, 2013 1:03 pm
It is often documented that you should always put a 5mm spacer above your stem.
Campagnolo; because I ride a bicycle, not a fishing rod.
M∆SON Definition / Camapgnolo endurance & bikepacking build - ~8.4kg
There are no new unread posts for this topic. New Zipp carbon stem and seatpost
mariovalentim
15
1928
Fri Feb 17, 2017 9:58 am
Marin View the latest post
There are no new unread posts for this topic. Actual length Zipp Service Course SL stem
Dr.Dos
9
856
Wed Sep 28, 2016 10:07 am
Fiery View the latest post
There are no new unread posts for this topic. Fetha mount for Zipp Service SL Stem
SpecializedColnago
7
307
Tue Feb 21, 2017 4:13 pm
Shrike View the latest post
There are no new unread posts for this topic. Zipp 303 vs Zipp 404 chainstay rub
nemeseri
Thu Feb 16, 2017 6:01 am
are View the latest post
There are no new unread posts for this topic. Zipp 303 NSW?
troydupe
Thu Jun 23, 2016 6:32 pm
4151zero View the latest post
Users browsing this forum: No registered users and 22 guests
