It is currently Wed Jan 17, 2018 12:27 pm
Post new topic  Reply to topic  [ 2 posts ]
PostPosted: Sun Jun 09, 2013 3:53 pm
Hi there,
I picked up a set of Zipp 101s and the rear wheel brakes unevenly. Even under very moderate deceleration, I feel a very strong pulsing in the brake as if it's catching only on part of the wheel. Under hard braking it chirps loudly and pulses hard at each "catch." The wheels have 600 miles on them.
The hub is tight, the wheel is true (according to 4 different techs at different shops), and my brake pads are properly adjusted for the wheel. We even filed them down to bring up a fresh surface, and still the terrible rear braking persists. Does anyone know what could be causing this? I've heard that sometimes the braking surface can bulge or bubble on new wheels which seems totally plausible given my situation. If that's the case, how can I check for that and prove that's the issue? If I can't sort this out, next stop is the Zipp warranty department which I'm not looking forward to.
Thanks!
 Post subject:
PostPosted: Sun Jun 09, 2013 4:02 pm
Try lowering the brake pads about a millimeter from where you have them. My front 101 exhibited this until I noticed that the pads were a bit higher than I had them on the rear wheel. When I lowered them, it was gone.
Sent from my EVO using Tapatalk 4 Beta
 Post subject:
There are no new unread posts for this topic. REAR HUB ZIPP 188
nick007
Thu Aug 24, 2017 9:20 am
kavitator View the latest post
There are no new unread posts for this topic. Sram etap battery keeps breaking
charlieboy52000
Wed Jul 26, 2017 9:32 pm
charlieboy52000 View the latest post
There are no new unread posts for this topic. Damaged surface of Campagnolo Ultra Torque PressFit Cups
3Pio
32
2048
Sun Oct 15, 2017 5:44 pm
winkybiker View the latest post
There are no new unread posts for this topic. Space for a Wahoo mount with Zipp SL Sprint + Zipp SL 70 Aero setup?
Shrike
Fri Nov 17, 2017 10:08 am
Shrike View the latest post
There are no new unread posts for this topic. Zipp SL-88 vs. Zipp SLC2 TB
TSJ
Thu Sep 21, 2017 8:55 pm
TSJ View the latest post
Users browsing this forum: Ettore, Greatestalltime, wingguy and 42 guests
cron
