It is currently Mon Jul 24, 2017 11:52 am
Post new topic  Reply to topic  [ 22 posts ]  Go to page 1 2 Next
PostPosted: Thu Jun 06, 2013 6:55 am
a friend of mine and i both ride Scott bikes and on his, the carbon dropout on the non-drive side seems to be eating in by the lightweight skewers he's been using which is the external type.
i have the skewers from Farsport, which are also external types and got me worried. so i checked mine... and lord and behold... http://img812.imageshack.us/img812/3407/dropout.jpg" onclick="window.open(this.href);return false;
it's not major right now, just seems the paint part got rubbed off and getting into the carbon.
so long story short.. my friend forward me this article...
http://m.bikeradar.com/gear/article/ang ... ers-36417/" onclick="window.open(this.href);return false;
it talks about using internal mechanism type of skewer instead of external. perhaps this will prevent more rubbing into the carbon dropout by using skewers like these: http://www.starbike.com/en/tune-ac16-17/" onclick="window.open(this.href);return false;
what do you guys think? am i too paranoid? or is this just another way of marketing a plain o'skewers? :mrgreen:
PostPosted: Thu Jun 06, 2013 7:12 am
my preference is for internal cams, but i've been using a few different sets of cheap and not so cheap external cam skewers for a while with no complaints. if you want to sleep easy, the big 3 all sell very ordinary, heavy but time tested and reliable internal cam skewers for not much more than the super-light TI stuff that's coming out of china.
PostPosted: Thu Jun 06, 2013 7:14 am
the big three you refer to are the same one listed in the angryasian article? also, how can you tell if it's internal cam or not? besides the weight.
PostPosted: Thu Jun 06, 2013 8:48 am
They didn't happen to much before because dropouts were still aluminum. I've seen this happen recently with my teammate's new TCRs with carbon dropouts. Luckily reps from Giant were visiting the LBS that week, and promptly brought the frame back to Taiwan and vowed to do some R&D.
PostPosted: Thu Jun 06, 2013 9:01 am
interesting.. I recently picked up a DA wheelset and have been using the heavy shimano skewers.. Having been used to ti skewers over the last few years, the action on these felt surprisingly solid and smooth.. however they're 130g and need to go.
What about the DTSwiss road Ti skewers? They've got some slightly different locking mechanism..
PostPosted: Thu Jun 06, 2013 5:47 pm
Just look at it. If it looks like a lever going into a pod, it's internal. If it looks like a lever pushing against a plate, its external.
Edit: http://sheldonbrown.com/skewers.html
PostPosted: Thu Jun 06, 2013 8:42 pm
Any recommendations for light-ish internal cam skewers, something lighter than the Shimano and Campy variety? I've pulled the rear wheel partway out of the NDS dropout a couple of times recently with the Ti skewers I've been using. They tend to loosen up while riding which makes things exciting. :shock:
PostPosted: Thu Jun 06, 2013 8:49 pm
If you want internal cams, you're going to have to live with the weight. You'll never find anything close to what you can get with external. If you need the security, you have to be willing to sacrifice the weight. I'll look around though, might surprise myself.
Edit: Velo-Orange has some very nicely priced ones that aren't complete boat anchors: http://store.velo-orange.com/index.php/ ... ewers.html
PostPosted: Thu Jun 06, 2013 8:52 pm
Good topic. What is that one on Contador's wheel?
PostPosted: Thu Jun 06, 2013 9:55 pm
What kind of rear dropout do you have? Horizontal or vertical? Material?
Which model/brand (or no name ebay cheapo) skewer? Has it gotten worse over time?
Several decades ago I managed to have a tire rub the chain stay due to slippage on a horizontal dropout, but I've never done it with a vertical dropout.
PostPosted: Thu Jun 06, 2013 10:15 pm
These are probably the lightest internal cam skewers. Tune AC14
http://www.starbike.com/en/tune-ac14/
PostPosted: Thu Jun 06, 2013 10:44 pm
@tinozee: they look like the tuned version.
@RussellS: what's the difference between teh ac14 vs. the ac16-17 i posted? they look nearly identical.
PostPosted: Thu Jun 06, 2013 10:45 pm
HammerTime, carbon, vertical dropouts. It has only happened twice, within the last month or so. They are the skewers on my tubs so they don't get used all the time, and I've been swapping the rear for a heavier skewer in races. Skewers are from Bike Hub Store, so the same ones you'll find on ebay. It is an issue when getting out of the saddle at low speeds, the rear wheel shifts towards the NDS chain stay and pulls part way out of the dropout. If I check them before every ride it is fine, so that is the simple solution.
The weight is right on the Tune skewers, but they ain't cheap!
PostPosted: Thu Jun 06, 2013 10:58 pm
@Wookieopolis: granted the tuned version aren't cheap for sure.. but if they provide internal cam locking mechanism and longer life for my frame.. it just might be worth it. :)
holy crap... even with the 10% off.. it's like $116.44. :unbelievable:
PostPosted: Thu Jun 06, 2013 11:04 pm
One is MTB and the other is road, so the difference is probably about 5mm. :D
There are no new unread posts for this topic. Supersix Evo to Synapse - thoughts ?
G6612
10
1459
Sat Apr 22, 2017 12:50 pm
Rev View the latest post
There are no new unread posts for this topic. Designing frame thoughts
53cxzero
16
1116
Wed Oct 12, 2016 5:54 pm
53cxzero View the latest post
There are no new unread posts for this topic. Etap upgrade - thoughts
G6612
Fri Aug 26, 2016 4:42 pm
G6612 View the latest post
There are no new unread posts for this topic. Thoughts on switching frames?
baldwintodd
Mon May 08, 2017 4:46 pm
kulivontot View the latest post
There are no new unread posts for this topic. Thoughts on the new Trek Madone...
mile2424
Sat Sep 24, 2016 2:02 am
BeeSeeBee View the latest post
Users browsing this forum: Bogan, Brus, CarlosFerreiro, gmarsden, llhh, Pajjy and 35 guests
