What the lightest and cheapest AL seatpost?
g32ecs
by g32ecs
Am I asking for too much?
200g>, $50>
I think the Deda Zero 1 stem is a steal @ $30> each . They're 130g (even less on my scale). Just looking to see if there's a seatpost counterpart at the $50> pricepoint.
The carbon seatposts from China look fine but I cannot deal with the long wait.
Tokyo Drifter
by Tokyo Drifter
kcnc. they flex like crap though, and I don't trust them not to turn into an arse-skewer.
Barrie
by Barrie
6k Cycles on ebay
$99 for a 27.2 x 240 103g from the USA
http://www.ebay.co.uk/itm/6KCycles-Ultr ... 460f72569a
Barrie
Devon
by Devon
I have the Planet X Superlight Team 3D Forged on my winter/trainer, comes in just a tad over 200g in my size IIRC and it's pretty damn stiff and dirt cheap.
EDIT: http://www.planet-x-bikes.co.uk/i/q/SPP ... oyseatpost
Campagnolo; because it's a bicycle, not a fishing rod.
LouisN
by LouisN
Ritchey WCS V2 aluminium. Available under $50.
The 27.2 X 280 mm should be just around 200g.
Bomb proof.
Louis :)
dgran
by dgran
I would just try to find a used Thomson. Hard to go wrong with them.
wrcompositi
by wrcompositi
I use Token TK9191 alu seatpost. Zero setback, 146g for 27.2x350mm, reduced to 129g when I cut off 90mm. Price is about USD$70 locally.
odin99
by odin99
Woodman Post SL Plus seatpost - claimed weight on ebay for 27.2 x 400 is only 188g. not bad. lighter if you cut. $42 + $7 ship < $50.
ednino
by ednino
Tokyo Drifter wrote:kcnc. they flex like crap though, and I don't trust them not to turn into an arse-skewer.
I've got KCNC scandium bars/stem/seatpost on road & XC bikes
The bars have some flex but I've never had any trouble.
MarkMcM
by MarkMcM
The U.S.E. Alien Aluminum seat post isn't super cheap (around $90), but it is quite light, at around 170 grams for the 270mm length road model.
53x12
by 53x12
Have had my KCNC for over 3 years now. No issues, problems or concerns. No flex either. How much do you weigh there?
bura
by bura
Still we do not know what size (dia ,length,design-setback or no) this " lightest and cheapest" post needs to be.
OP?
Kuota Kom Evo
viewtopic.php?f=10&t=111825&p=955235#p955235" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
SOLD
addictR1
by addictR1
i checked around.. is KCNC the lightest alloy seatpost that won't break the bank?
look for a 270mm version under 127g with good range of adjustments and can use on carbon rail if needed.
i tried the one from 6Kcycle on ebay.. but noticed it's not 31.6mm all the way through from top to bottom. so in some sections where i needed it clamped it.. it won't.
but that one was 127g though.
mattyNor
by mattyNor
Thomson elite or masterpiece
tibikeboy
by tibikeboy
I second mattyNor's answer. Thomson Masterpiece seatpost is strong and light and you can use carbon rail saddles without having to buy a separate clamp. You can lighten up by buying some titanium bolts. You can purchase the titanium bolts from Toronto cycles.
