Cannondale C1 vs. 3T Pro cockpit
Helmutti
by Helmutti
Hi all.
Im in doubt here. Im buying the Caad10 black inc size 52, and it comes with the C1 version Cannondale handlebars and stem. I'm a big fan of 3T and therefore I bought the 3T pro stem (110mm) and 3T ergonova pro (40cm)
I have a really hard time finding any weights on C1.
My 3T weights in at 425g.
Will there by any weight gain or loss if changing to 3t?
cerro
by cerro
Think weight gain, don't really know exact C1 weights but the 3T Pro handlebar is heavy.
/jonas l
SUCycling88
by SUCycling88
The C1 stuff is pretty dang light, not sure about the 3T stuff tho
Helmutti
by Helmutti
Okay, thanks a lot. I'll keep the C1 and try to find other places to loose weight :)
sigismond0
by sigismond0
Yeah, you're basically comparing C-dale's top of the line parts with 3T's bottom rung. The C1 will beat out Pro every time, you're looking at LTD if you want to see an appreciable difference.
are
by are
I have an extra C1 or C2 stem - don't remember which - it's light, but doesn't feel solid. I use Syntace now, but I also had a Deda Zero 100. Both the Syntace and Deda seem much better built. I believe awhile back the Cannondale stems were re-branded Syntace, but I don't think that's the case anymore. I know everything is tested and approved, but I didn't feel the Cannondale stem was safe, so I got the Syntace and have been very happy with it. I know this is WW, but I wouldn't go nuts saving weight on bars and stem - if something fails, it'd be bad.
cerro
by cerro
120g for a 100mm C1 stem I heard at work today.
/jonas l
PSM
by PSM
My 3T Ergosum Pro 420 weigh 237 gram. Not too heavy...
