It is currently Tue Jan 23, 2018 1:43 am
Post new topic  Reply to topic  [ 22 posts ]  Go to page Previous 1 2
PostPosted: Tue Jun 04, 2013 6:05 pm
Maybe the shifter is moving on the bars? Same effect as wrong cable tension, but maybe harder to notice if the movement is very slight and only when you push/pull on it. Seems unlikely, but it happened to me once. Of course you'd also likely notice it in your braking.
PostPosted: Wed Jun 05, 2013 2:25 pm
Agreed on the comment about shifter moving on bars. Happened to me the 1st time I installed Sram Red (1st gen) onto my bike that I had Dura-Ace 7800 back in the day.
I never really had to put high amounts of torque to the clamp for the shifter with Dura-Ace. So I did the same with Sram, it would slip down as I rode on the hoods. Took me weeks to figure it out, and now I torque the sram red hoods to recommended torque (pretty high) and no more ghost shifts in the back and no more rubbing front derailleur.
http://www.hackracer.com/
PostPosted: Thu Jun 06, 2013 6:53 am
One other thing I thought of is that there is an extra trim position on the small ring. The instructions for setting up limits and cable tension for the FD are not quite the same as old Shimano FDs. I would double check the dealer manual for the FD and shifters to be sure that you are setting it up correctly again. Though your mechanic may be awesome, the FD setup is a little different and maybe they didn't realize that.
PostPosted: Sat Jun 08, 2013 2:27 am
Ive got 2 bikes in the shed running DA9000 mech. I pulled out a bit of hair before I worked out: THERE IS EXTRA TRIM IN THE SHIFT!
So there was only 2 trims in the past on shimano FD's. With DA9000 there is THREE!
So when you are in the easiest gear, front and back, and its rubbing, trim the shifter one more time.
My YT channel
http://www.youtube.com/user/durianriders?feature=mhee" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Follow me on Strava
http://app.strava.com/athletes/254600
PostPosted: Fri Mar 13, 2015 5:39 am
Did you ever solve your problem? I have the same exact issue with DA 9070. It can't be the trim because the dérailleur is auto-trimming. I think it is the chain. I am about to test my theory and swap it out with a KMC or Ultegra.
R2.5 / R3 / S-Works 29er (20 lbs) / S-Works SL4 Di2 (14.7 lbs)
PostPosted: Fri Mar 13, 2015 5:29 pm
Is the rub when using the big or small chainring? When I moved our DA 9000 over to 9070 drive trains, setup was not difficult, but I found I really needed to pay close attention to the setup instructions provided in the Shimano 9070 Dealer Manual as some tolerances are less than 1mm which can make a difference with the front derailleur alignment/trim.
PostPosted: Fri Mar 13, 2015 6:14 pm
It is on the big chain rig. Same situation,quiet on the stand and noise in certain gears on the cassette. I have tried every adjustment possible. I don't understand how it could drag on both sides of the cage depending on the rear gear. It should auto-trim in or out for the corresponding rear gear
There are no new unread posts for this topic. Dura ace 9000 rear derailleur?
sinjun
Mon Apr 10, 2017 6:02 am
richscott View the latest post
There are no new unread posts for this topic. Dura ace 9000 V 9100 brakes
scottmmw
Mon Oct 23, 2017 7:51 pm
evan326 View the latest post
There are no new unread posts for this topic. 28C tyres on Dura Ace 9000 Brake Calipers
chutneyyy
Thu Jun 29, 2017 7:58 am
Delorre View the latest post
There are no new unread posts for this topic. Dura Ace 9100/9150 noisier than 9000!
James0133
11
3529
Sun Aug 20, 2017 5:44 am
James0133 View the latest post
There are no new unread posts for this topic. Shimano Dura Ace 9000 free hub body backward compatibility?
BeeBee30
Wed May 17, 2017 7:32 am
petal666 View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Google Adsense [Bot], Hexsense, Majestic-12 [Bot] and 35 guests
