It is currently Sat Feb 25, 2017 3:11 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Sat Jun 01, 2013 7:38 pm
I bought a used rear Super Record 11 derailleur from a friend and one of the jockey wheels is missing a tooth. It works fine, but that bothers me. I've priced out some replacement pulleys and a lot of ceramic aftermarket pulleys are barely any more money.
Does anyone have any experience running the following:
Tiso Ceramic (not the full ceramic, the cheaper version)
Enduro Zero Ceramic (hybrid, not full ceramic)
or anything in a similar price range of $80-$100?
If there isn't any sort of real difference in quality I won't bother. I know Velonews did a pulley wheel test, but I don't seem to have the results anywhere.
Gramz
Strava
PostPosted: Sat Jun 01, 2013 9:18 pm
Nothing wrong with the original equipment - actually I'd take it anyday over aftermarket - quiet, super low resistance, reasonalby priced ($55 from totalcycling.com).
Check this out - mine do the same after a full season with no maintenance http://www.youtube.com/watch?v=0IGCXDo8WcY
PostPosted: Sat Jun 01, 2013 9:31 pm
Buy the friction-facts pulley report and then make your decision. As a hint - you can get lower resistance with a good steel bearing pulley than the SR stock.
http://www.speedtheory.co.nz
http://www.velogicfit.com - 3D Motion Capture and Frame Finder Software
PostPosted: Sat Jun 01, 2013 9:54 pm
http://hawk-racing.com/products/show/37" onclick="window.open(this.href);return false;
and
viewtopic.php?f=3&t=67497
:D
PostPosted: Sun Jun 02, 2013 1:34 am
Check this out - mine do the same after a full season with no maintenance http://www.youtube.com/watch?v=0IGCXDo8WcY" onclick="window.open(this.href);return false;
Strangely enough, my brand new SR11 rear D pulley wheels spins fopr like 1.5 seconds only, any reason for the discrepancy? A friend says the grease is probably removed from those in the video. I am tempted to get some serious ceramic ones as well, but am wondering if it'll save even a watt...
Trek Mad-one 7 Series team colours http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=115500&start=15
PostPosted: Sun Jun 02, 2013 1:57 am
Mine were oiled from the factory - and then a year later I oiled them once again - not because I sensed an issue but just 'cause it was winter time and so it seemed like the thing to do. But before removing and oiling mine they performed just like in the video that I linked to above.
BTW - most aftermarket pulleys also lack the float for the top pulley - another consideration...........
PostPosted: Sun Jun 02, 2013 10:26 am
I use extralite pulleys they work great and drop a cool 10gs, they spin and shift as well as std SR jockeys and are much easier to keep clean..
Skunkworks Bikes
PostPosted: Mon Jun 03, 2013 2:19 am
Kayrehn wrote:
Strangely enough, my brand new SR11 rear D pulley wheels spins for like 1.5 seconds only, any reason for the discrepancy? A friend says the grease is probably removed from those in the video. I am tempted to get some serious ceramic ones as well, but am wondering if it'll save even a watt...
The super record lower pulley is ceramic. Never had grease, it ought to be lightly oiled or nothing. Upper one is a plain bushing to allow lateral float. I haven't tried it, but Shimano DuraAce has an upper pulley that is a bearing AND allows lateral float. I personally would not replace the upper one with one that does not float. Shifting adjustment will be more finicky, temperamental. Your experience may vary.
Sent from my EVO using Tapatalk 4 Beta
PostPosted: Mon Jun 03, 2013 8:34 am
they look great also :) but are they compatible with SR? ...11
PostPosted: Mon Jun 03, 2013 11:12 am
Yup I've used em with 2010 chours, 2010 Sr and 2012 SR. They work every bit as good as the SR pulleys.. Not noisy either
Skunkworks Bikes
PostPosted: Mon Jun 03, 2013 12:42 pm
Does that mean you did't have any issues with shifting?
PostPosted: Mon Jun 03, 2013 2:17 pm
http://www.competitivecyclist.com/revie ... s_450.html
:D
PostPosted: Tue Jun 04, 2013 5:31 am
Shifting is great! No issues what so ever
Skunkworks Bikes
PostPosted: Fri Apr 10, 2015 8:44 am
Can I used in SR cage 13 teeth instead 11 or combination 11/13?
and what are the benefits?
There are no new unread posts for this topic. Sram Red 22 med cage with 15 t jockey wheels ?
chris14
Sun Mar 20, 2016 8:18 pm
chris14 View the latest post
There are no new unread posts for this topic. Aftermarket fork for CAAD12 ???
namejoker
Tue Sep 27, 2016 12:40 am
rms13 View the latest post
There are no new unread posts for this topic. Aftermarket aero road disc brake fork
Epic-o
Sat Jan 07, 2017 8:18 am
spookyload View the latest post
There are no new unread posts for this topic. Aftermarket brake choices for Shimano 6800/9000
ultyguy
Wed May 11, 2016 6:46 am
Anders3404 View the latest post
There are no new unread posts for this topic. Chain falls off lower jockey wheel SRAM Red 22
octave
Sat Feb 04, 2017 9:06 am
Tom14 View the latest post
Users browsing this forum: Baidu [Spider], BdaGhisallo, Bing [Bot], gerryc89, Google [Bot], Yahoo [Bot] and 27 guests
