It is currently Fri Feb 24, 2017 4:43 am
Post new topic  Reply to topic  [ 5 posts ]
 Post subject: BB30 Compatibility
PostPosted: Thu May 30, 2013 9:18 pm
hi,
i have a lapierre 9it's a 2012 Xelius) that currently has a SRAM S900 crankset in the press-fit BB. i would like to use this on a new cannondale supersix that has a BB30. can i use this crankset and if not what adapter or BB do i need to get to make it compatible? thanks.
 Post subject:
PostPosted: Thu May 30, 2013 9:32 pm
It is directly compatible. You will need a bb30 bearing kit for the other bike (bearings, shields, circlips), and then it drops in.
Sent from my EVO using Tapatalk 4 Beta
 Post subject:
 Post subject: Re:
PostPosted: Thu May 30, 2013 9:46 pm
hi,
thanks! appreciate the help.
 Post subject: Re:
PostPosted: Fri May 31, 2013 12:09 am
Are you sure? I'm not familiar with the bike after looking online it looks like it's a BSA frame. It would still work on the Supersix, you would just need some sort of adapter like the Wheels Manufacturing BB30 to SRAM adapters.
Edit: Do you have crank bolts on both cranks or just the non-drive side crank?
 Post subject:
PostPosted: Sat Jun 01, 2013 12:11 pm
Correction: it is especially confusing due to you having an S900 crankset, which I THOUGHT only came with a 30mm spindle. It apparently was also available with a GXP fitment. It will still fit in a Cannondale bb30 frame, you will instead need the bb30 bearings plus a WheelsMfg bb30-to-GXP ADAPTER.
There are no new unread posts for this topic. Record EPS V3 DTI compatibility
jnygaard
Thu Mar 24, 2016 8:59 pm
Miller View the latest post
There are no new unread posts for this topic. Campagnolo EPS compatibility
pritchet74
18
1678
Sat Jan 28, 2017 3:05 am
Valienteboy View the latest post
There are no new unread posts for this topic. campagnolo compatibility old and new
rickmm
7
672
Mon Nov 21, 2016 3:16 pm
graeme_f_k View the latest post
There are no new unread posts for this topic. Attachment(s) Shimano Compatibility
Valbrona
Mon Jan 02, 2017 10:55 pm
ooo View the latest post
There are no new unread posts for this topic. Cannondale SISL2 compatibility
Bely
Wed May 04, 2016 4:14 pm
KimJaeCheon View the latest post
Users browsing this forum: Bing [Bot], em3, Lukester, sedluk, Yahoo [Bot] and 17 guests
