It is currently Sat Jun 24, 2017 8:04 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Sun May 26, 2013 5:52 pm
Hi,
I'm running 34/48 chainrings on my compact campagnolo cranks and want to pair it with a 13-29 cassette on my Campagnolo Record 10 speed shortcage derailleur. Will this work, or am I running a risk of tearing it all apart?
thanks
PostPosted: Sun May 26, 2013 8:51 pm
The Campagnolo spec sheet for the 10 speed Centaur short cage rear derailleur says the following:
RECOMMENDED COMBINATIONS
Double crankset (52-39 or 53-39) or CT crankset (50-34) + short cage rear derailleur: all 10s Campagnolo sprocket sets.
I think you are safe. Size the chain to fit the 48x29 gear. And then try to never use the 34x13 or 34x14 or 34x15 gears.
PostPosted: Mon May 27, 2013 2:47 pm
The total wrap with a 48/34 is less than if a 50/34 was used, so there will be no problem and no need to size the chain for the 48/29 or to avoid using the 34 with the smaller cogs, since the chain will not hang loose.
Use the normal Campy-suggested little/little method for sizing the chain.
PostPosted: Mon May 27, 2013 7:13 pm
thanks guys, I will give it a go then :-)
PostPosted: Tue May 28, 2013 1:09 pm
Max wrap for a short cage RD is 30T, which I know from experience. Obviously, chain length needs to be done correctly. OP's wrap is 30T, so he's fine.
There's sometimes a buggy.
One.
There are no new unread posts for this topic. Campagnolo Post Mount Disc Work Around
morrisond
15
1270
Sun May 28, 2017 9:37 pm
motorapido View the latest post
There are no new unread posts for this topic. Campagnolo Front Derailleur Question
matty
16
736
Sun Mar 19, 2017 11:10 am
matty View the latest post
There are no new unread posts for this topic. S2-system on Campagnolo front derailleur
Daniel1975
Thu Jan 05, 2017 10:16 pm
Calnago View the latest post
There are no new unread posts for this topic. Campagnolo Super Record Rear Derailleur. 32t?
Ultimatek
Tue Aug 16, 2016 1:39 pm
graeme_f_k View the latest post
There are no new unread posts for this topic. Removing 2015 Campagnolo rear derailleur from hanger
timmbo
12
1166
Sat Jan 14, 2017 1:41 pm
timmbo View the latest post
Users browsing this forum: fabriciom, hlvd, Yahoo [Bot] and 52 guests
