It is currently Sat Oct 21, 2017 2:08 am
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: Sram red crank puller
PostPosted: Sat May 25, 2013 6:09 pm
hi, I have a sram red press fit bb30 crankset.. and could you tell me what kind of puller I need to remove the arm and crank??
thank you
I dont need the best one... the bolt is 10mm hex on the crank
Ninja
PostPosted: Sat May 25, 2013 7:00 pm
Crank bolt is a self extractor-no puller needed.
after 2 drinks I'm a loser, after 3 a star
PostPosted: Sat May 25, 2013 7:36 pm
^^^this
use the 10mm hex, it will start, then get harder to turn as the extractor engages, keep turning and it will get easier again
PostPosted: Sat May 25, 2013 7:48 pm
yes but the arm is usualy hard to remove
Ninja
PostPosted: Sat May 25, 2013 8:35 pm
there is no puller, you just have to undo the bolt to release the two parts of the crankset
if you mean that you have undone the bolt but cannot get the spindle out of the bearings, use a rubber hammer (or put a book between metal hammer and spindle) and gently tap the end to drive it out
see sram's instructions if you are not clear as there are plenty of pictures showing what to do, they are on the sram website
PostPosted: Sat May 25, 2013 8:42 pm
thank you
Ninja
There are no new unread posts for this topic. Crank Bearing Puller for SRM Campagnolo Crank
mrgray
14
959
Tue Apr 04, 2017 9:37 am
mrgray View the latest post
There are no new unread posts for this topic. q Angle on 2010 Sram red crank
Juanmoretime
Sat Nov 12, 2016 6:48 pm
mythical View the latest post
There are no new unread posts for this topic. SRAM red exogram crank with force 1
Wayne17
Fri Dec 30, 2016 7:36 pm
Lelandjt View the latest post
There are no new unread posts for this topic. SRAM Force left crank arm weight ?
Xico
Thu Feb 09, 2017 2:10 pm
darnellrm View the latest post
There are no new unread posts for this topic. Which power meter: Sram Red + Stages or Quarq Dzero Sram
[ Go to page: 1 2 3 4 5 ]
Shrike
70
9215
Sat Apr 08, 2017 10:20 am
JackRussellRacing View the latest post
Users browsing this forum: Attermann, Bing [Bot], Chris3g, Yahoo [Bot] and 29 guests
