It is currently Tue Feb 28, 2017 6:46 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Mon May 27, 2013 12:57 pm
My son is running 42/30 Extralite chainrings whith Shimano Udi2 (10-speed) and they work perfectly. He is limited to 5.78m rollout over here so that results in a max gear of 42/15. unfortunately, when using anything larger than a 13t outer cog, the chain makes contact with the seat stay. Very frustrating....!!!!
PostPosted: Mon May 27, 2013 1:03 pm
Could you use the existing cassette, removing the 12t cog and replacing it with a (custom) spacer? you would have 10 cogs on 11 speed spacing but technically wouldn't be blocking off gears.
Monkeyburger
...finding my inner Onoda-kun...
PostPosted: Mon May 27, 2013 2:31 pm
nah... the current Udi2 is 10 speed only.
PostPosted: Sat Aug 03, 2013 12:14 pm
Is there any info on when/if Shimano will release junior gearing?
It's best to just use a specific junior cassette instead of messing around with cassettes and front rings. Because they still need to be able to switch wheels in a race from the neutral car.
PostPosted: Sun Aug 04, 2013 2:28 am
There's an easy solution - put a 10 speed cassette with Ultegra 6800 and adjust the mech travel.
Users browsing this forum: oldturd, pantani83, rodebaron51, snowdevlin, sovereign, stevec1975, Wormiez, wrcompositi, Yahoo [Bot] and 40 guests
