It is currently Wed Jan 17, 2018 12:31 am
Post new topic  Reply to topic  [ 24 posts ]  Go to page 1 2 Next
PostPosted: Sat May 25, 2013 4:36 am
Hi guys, I have a choice to make between riding Reynolds Assaults 2009 or Zipp 101 2011 wheels. Which would you go with, assuming you will be climbing and riding flats equally? There are the obvious initial differences, like rim depth and weight, but I'm interested in opinions of those who have ridden both. TIA!
PostPosted: Sat May 25, 2013 11:29 am
I'd avoid the 2009 Assaults - I owned a pair for a few months back then - they are really just low to mid-level Far East wheels with branding - flexy and one of the worse brake tracks ever. They would rub front and back even when climbing at moderate effort. They also gave me a death wobble shimmy descending at speed (despite being true), that I've had with no other wheels on the same bike, including other mid to high profile carbon wheels. They're also not terribly light or aero and come from the era when melting brake tracks was common. I saw this happen to someone else once (a skilled friend descending Palomar east grade - prolonged descent, not too technical or much braking). They are the epitome of the "it looks good but serves no purpose" poseur carbon clincher. If you insist on an all carbon value clincher, look at Boyd. I think the whole CC genre varies from crap (most) to beta technology (Zipp, Enve) at present. If you need aero and light weight for racing, get tubulars in one of the new wider iterations (Zipp Firecrest/Enve Smart). Otherwise, carbon clinchers look good at a distance, but don't serve any functional purpose. They may look racy on the B group ride, but scream 'Fred' to the knowledgeable (Yes, I was guilty. We all learn and evolve.). If you insist on carbon clinchers, the Mavic line (alloy brake track or the new embedded aluminum in carbon) seem well thought out from a quality and safety perspective and make some sense if you live/ride in a relatively flat area.
No personal experience riding the 101's. They seem like a well thought out design, but seem a little pricey for an alloy wheelset. However, you're on the right path with a wide, semi-aero alloy wheelset. 23 mm rims with latex tubes and good tires come damn close to tubulars for ride quality and make sense from a convenience standpoint. State of the art these days, excepting race day tubulars. If so inclined, you could replicate the 101's with any one of a number of handbuilt sets with equal quality components at a lower price point. There are now a few wide, semi-aero rims out there. Check with one of the great wheelbuilders. Ergott, Zen Cyclery and I believe Justin Spinelli all inhabit this website periodically.
If you're looking at two used sets and this is an 'either/or question', go with the 101's no doubt.
Happy riding.
PostPosted: Sat May 25, 2013 12:30 pm
Agree with comments on Reynolds. 101 very expensive and somewhat fragile.
Sent from my HTC One XL using Tapatalk 2
N+1 It Never Stops
PostPosted: Sat May 25, 2013 2:50 pm
Haven't ridden Assault clinchers, but at least my tubular versions are stiffer than Hyperons and have better braking too...
Idamelio: Aren't all carbon clinchers for posers?
tumblr
PostPosted: Sat May 25, 2013 3:03 pm
If its an alloy clincher your after, consider Rolf Prima.
The Vigor is very light and at 34mm deep more aero than both.
It it's weight, have a look at their Élan.
I use both the VigorSL (road) and VigorFX (track) and am very satisfied.
PostPosted: Sat May 25, 2013 4:29 pm
That being said, the Zipp 101's outperform many deeper rims in terms of aero...
PostPosted: Sat May 25, 2013 7:34 pm
Apparently not the rolf primas http://www.rolfprima.com/techinfo_aero_ ... -alloy.php
I'd second the rolfs, I had a pair and they were great
PostPosted: Sat May 25, 2013 9:41 pm
No offense but I have pretty much 0 trust for rolf's own material. They don't even show a yaw plot or multiple runs, nor do they show any development insight.
I'd put money on the 101s being more aero in an independent test
PostPosted: Sun May 26, 2013 12:09 am
Just to show the other side of the coin, I've happily been on Reynolds Assaults and Attacks for a couple of years now with no issues. Descending (fast with zero "death" wobble) and ascending (slow to very slow usually) mountains in UT and CO, they've stayed true and the brake tracks haven't self-destructed despite my nearly exclusive use of latex tubes.
Then again, I'm apparently just a Fred poseur that's not as enlightened nor as knowledgeable as an earlier poster.
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Sun May 26, 2013 12:35 am
Don't get the 2009 Assaults, they are rubbish as the other posters have said. The 2011/2012 Assaults are much better.
PostPosted: Sun May 26, 2013 3:16 am
Reynolds redid their brake tracks for 2011. Prior to that, they're a crap shoot. If those are your only options, I'd go for the 101's.
PostPosted: Sun May 26, 2013 6:10 am
Not true FIJIgabe, I have 2010 Assaults (no scrim surface) but braking is excellent with Reynolds cryo blue pads...
tumblr
PostPosted: Sun May 26, 2013 2:33 pm
Interesting stance. I'd personally vouch for the Rolf's. Excellent wheelset and much better priced. Additionally, being a smaller company they will custom build to meet personal needs at no extra cost.
I take all company aero claims with a grain of salt. They only ever release favuorable information. Nothing beats rim depth in the end - deeper=less spokes=aero, aerofoil shape assist handling and wind affects.
PostPosted: Sun May 26, 2013 2:52 pm
The reason I don't buy Rolf's aero data is because it's way off what every other test has ever shown. When HED says they're slightly faster than Zipp and Zipp says they're slightly faster than HED, and Trek wheels are very close to both, etc..., I can accept that differences in setup or test protocol will skew the results one way or the other. When they all say Rolf wheels (and Reynolds) are noticeably slower, and semi-independent tests confirm it, I have to rule out Rolf's data almost entirely.
...and I've seen a lot of recurring broken spoke issues with Reynolds' cheaper wheels, even after only a couple months. I'm not saying the 101 have a stellar record, but they're still the ones I'd go with.
PostPosted: Sun May 26, 2013 7:57 pm
I just like the part where a 32h box rim is still 6 seconds faster than a ksyrium elite
There are no new unread posts for this topic. QR skewer shopping - Zipp v Enve v Reynolds
Shrike
34
3260
Tue Feb 07, 2017 5:00 am
Johnny Rad View the latest post
There are no new unread posts for this topic. Space for a Wahoo mount with Zipp SL Sprint + Zipp SL 70 Aero setup?
Shrike
Fri Nov 17, 2017 10:08 am
Shrike View the latest post
There are no new unread posts for this topic. Zipp SL-88 vs. Zipp SLC2 TB
TSJ
Thu Sep 21, 2017 8:55 pm
TSJ View the latest post
There are no new unread posts for this topic. Attachment(s) Can you identify this Reynolds hub?
MarkH
10
963
Fri Apr 21, 2017 1:53 pm
CLEAR View the latest post
There are no new unread posts for this topic. Reynolds Strike SLG
poppiholla
Tue Jan 17, 2017 8:57 pm
poppiholla View the latest post
Users browsing this forum: trimenc and 30 guests
cron
