It is currently Thu Jan 18, 2018 3:19 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Fri May 24, 2013 2:09 pm
Built up a Z5Sli from Wrenchscience's closeout and it is pretty sweet.
However, the chainstay mounted battery sticks in beyond the stay a few mm, and under my massive (ha) watts, my Velocity A23 700x23 GP4000 tire rubs against the battery.
Anyone have a clever suggestion for spacing it out a bit? I'm considering notching the mounting hole with a dremmel to swing it out a bit. The tire doesn't rub on the other side of the chain stay.
PostPosted: Fri May 24, 2013 2:24 pm
Is it just the part of the battery that's farthest from the stay? If so, angled washers could tilt the battery away from the tyre slightly.
Snacking on carrot sticks - Where did it all go so wrong?
Finsbury Park CC
PostPosted: Fri May 24, 2013 3:49 pm
Any opportunity for you to get a different battery that mounts internally in the seattube?
PostPosted: Fri May 24, 2013 3:59 pm
Matt is on to something with the angled washers, I think. Best solution (save for internal battery) IMHO.
Nice bike, btw......black brakes would be a nice addition, as would be black handlebar tape.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Sat May 25, 2013 2:17 am
You could file the battery mount a little, just the part that contacts the frame. File it at an angle, obviously...
PostPosted: Sat May 25, 2013 4:14 am
I ended up doing a combination of all of the above. Seems to be in-line with the chain stay now. Hopefully that does it, otherwise the 700x23 Gp4000 is just too fat on the A23 rim (measures 24.6 mm wide), or my wheels are too floppy.
There are no new unread posts for this topic. Pro Vibe Seatpost w/ di2 battery
raggi
Tue Oct 24, 2017 10:44 pm
raggi View the latest post
There are no new unread posts for this topic. Di2 battery drain problem
quango2k
Tue Feb 21, 2017 1:30 pm
Pokerface07 View the latest post
There are no new unread posts for this topic. Di2 BT-DN110 Battery Discharge
gazzaputt
Sat Nov 04, 2017 7:43 pm
kode54 View the latest post
There are no new unread posts for this topic. Mysterious Di2 battery drain
havana
26
2294
Fri May 26, 2017 6:45 am
eaglejackson View the latest post
There are no new unread posts for this topic. EW-WU111 with a SM-BTR2 battery for only ANT+?
Gearhead65
10
1760
Tue Mar 07, 2017 8:05 pm
Users browsing this forum: HammerTime2, jimaizumi, MagicShite, springs and 32 guests
