It is currently Sun Apr 30, 2017 12:30 pm
Post new topic  Reply to topic  [ 13 posts ]
PostPosted: Thu May 23, 2013 10:29 am
Hi,
Anyone with insider knowledge as to if SRAM is intending to make (or already do make)52-36 compact chainrings for its Exogram Crankset - Im guessing with "22" upcoming its probably not a priority but would be nice...
PostPosted: Thu May 23, 2013 4:47 pm
They announced they were making 36/52 rings for the 22 set. IIRC they also said they were making them available aftermarket as well.
http://velonews.competitor.com/2013/04/ ... kes_282149"
Quote:
Crankset: Arm lengths down to 165mm; Yaw-compatible chainrings; hidden-bolt design; standard and compact rings as well as the new 52-36 chainring combinations available; 741g claimed with BB30
PostPosted: Thu May 23, 2013 7:27 pm
Is there any particular reason why you want the SRAM chainrings in 52/36?
You could also run Praxis' 52/36 combo and save a substantial amount of weight. They work perfectly well with the Exogram crankset when set up. Minor mod needed to run on the BB30 model due to a chamfer issue. But: lighter, cheaper, great shifting. Unless you don't like the look of them, of course!
PostPosted: Thu May 23, 2013 10:24 pm
The exogram rings shift better than Praxis.
PostPosted: Fri May 24, 2013 10:11 am
Because I do the almost Cardinal Sin of actually buying from a LBS here and I doubt they can get hold of Praxis rings in Mallorca. (And I do like the way it looks and shifts)
PostPosted: Fri May 24, 2013 2:47 pm
:shock:
Praxis > SRAM
If your LBS doesn't carry them you can buy direct.
PostPosted: Fri May 24, 2013 7:02 pm
I didn't throw that out there for the sake of favoritism. Praxis rings shift very well and save a good bit of weight - BUT - when used with the whole new red group they do not shift as quickly or precisely as the exogram rings. Considering Praxis doesn't even recommend the combo, I wouldn't call that a fault. If you didn't ride the exogram rings and switch to Praxis - you'd never suspect you're missing anything.
FWIW, I have 2 sets of praxis rings currently in use and have used 3 sets of exogram cranks.
PostPosted: Tue May 28, 2013 7:21 pm
Anyone know if they're going to be only for the new sram 22, or does 11/10 speed not make a difference in chainrings? Furthermore, I run a Quarq Riken, so will they shift ok even though they're rotated a couple degrees than normal?
PostPosted: Mon Jun 17, 2013 6:04 pm
I just called FairWheelBikes before placing an order for the Praxis 52/36 chainrings and the guy told me there is a slight modification that has to be done on the rings before they will fit the EXOGRAM crank. He said there was a post and a picture on Weight Weenies but I can't find it. Has anyone seen that and/or did the installation ?
Thanks in advance.
Paul
PostPosted: Mon Jun 17, 2013 6:10 pm
You'll find it over here:
viewtopic.php?f=3&t=103730
The 'modification' is one of two things: either ring rotation 180° (discussed around pages 7 through 11, I think, and verified by Praxis on page 10) or slightly filing down a tab to accommodate a chamfer on the crankset if you're running BB30. That is also discussed in there somewhere. The modification discussion gets picked up again around page 16, sorted again on page 17 (it was a repeat of the prior discussion).
PostPosted: Mon Jun 17, 2013 6:29 pm
I asked my LBS to register as a Praxis dealer. I want to see how that goes.
I like the tight combinations, though, so am excited by the 36-46 cyclocross set. There's also a 36-48. But I find the 46-11 plenty big for the riding I do. Hopefully the cross rings don't turn out heavy. In principle a 46 should be light.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Sat Feb 15, 2014 5:22 pm
Im aware of the inescapably poor form of bumping ones own post some half a year after it died. Be that as it may, does anyone have any inside information if SRAM wil EVER release 52-36 chainrings for its Exogram 10spd crankset, before I cross over to the dark side and get some Praxis rings plus a large pair of mole-grips to rip off the catch pin?
PostPosted: Sun Feb 16, 2014 1:22 pm
I was told end of April...I can see it getting pushed back with the hydro brake saga though.
Grover's Grumblings
Grover's Garage
There are no new unread posts for this topic. Sram red 22 exogram
Jowwy
Sat Apr 22, 2017 2:55 pm
Jowwy View the latest post
There are no new unread posts for this topic. SRAM red exogram 10 speed
Wayne17
Wed Sep 28, 2016 10:19 am
Jml View the latest post
There are no new unread posts for this topic. Sram Red exogram : chainrings option
stormur
Sun May 01, 2016 6:04 pm
stormur View the latest post
There are no new unread posts for this topic. SRAM red exogram crank with force 1
Wayne17
Fri Dec 30, 2016 7:36 pm
Lelandjt View the latest post
There are no new unread posts for this topic. Sram Red Exogram & Red eTap crankset difference/ chainring compatibility
stormur
Sat May 28, 2016 3:01 am
eric01 View the latest post
Users browsing this forum: chiumomo, johnnypedals, Oldfaithful and 35 guests
