It is currently Tue Jun 27, 2017 3:28 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Fri May 24, 2013 1:21 pm
I've been running sram since 2007. First force and then red. Never had an issue with the rear derailleurs and I had a force rear derailleur, red and even an apex RD on my TT bike.
Speedplay is the devil!
PostPosted: Fri May 24, 2013 8:32 pm
I've always noticed a lot of play in the arm of my Force rear derailleur, I've never had a problem with shifting but it's always seemed odd to me
PostPosted: Fri May 24, 2013 10:19 pm
fwiw my sram red shifts fine, but the axis of rotation of the cage is certainly not parallel to the axis of the rd mounting bolt...
with the hanger perfectly aligned and no chain (so nothing applying force to the cage) the cage at the extreme of clockwise rotation (viewed from drive side) gets much closer to the spokes than in normal position and at the limit the cage will just clip them, this position would never be reached with a chain on but it shows how far out of the line the axes of rotation are, it's not play in the mechanism, the cage is firmly in position
i always assumed it was by design, would be interested to know if others with sram red see the same difference in alignment
PostPosted: Mon May 27, 2013 12:56 am
Please post some pics of what you are describing.... we might get a better picture with which to provide more advice. I have worked on countless SRAM rear mechs and have never experienced what you are describing, but I am very curious. I am most interested in the pivot slop that you describe....IME SRAM rear mechs have noticeably tighter pivots (and last longer through heavy use) compared to Shimano.
EM3
______________
My 2013 Cervelo R5
PostPosted: Mon May 27, 2013 1:19 am
IT shifts beautifully. However, once in gear it sounds like a Sherman tank due to the pulley cage not being inline with the rear cogs.
A true testament to the toughness of their derailleurs is that I ran one that way for close to a year and it didn't just explode. Imagine how strong a derailleur has to be to survive being off center for 1,000's of K's. No slop in the cage or the body. The pulley bearings are still great as well. Mind you,, the teeth on the pulleys are in awful shape as you can well imagine.
I'm sure it's not an epidemic by any stretch and to be honest, the double tap shifters make the rewards far greater than the risks here. I was just curious as to if it was just me,, or have other folks noticed this. I'm going to try a couple of fresh hangers out this week and see if it makes it better, or worse. I have a full set of dropout and hanger tools, so I've just simply bent my current hanger to line up better (it's still far from perfect) with the gears. It'd be nice in the future though, if I didn't have to trash the hanger on every frame I own (And I own a lot) due to awful derailleur alignment.
PostPosted: Mon May 27, 2013 1:22 am
Just for shits and giggles, should a new 7900 chain run smoothly over a new force derailleur? My KMC chain ran smooth as silk until it gave out from the stress after about a thousand K's.
PostPosted: Thu Aug 18, 2016 2:15 am
same thing happened to me, brought a brand new rival medium cage to try out 11-32, the upper pulley does not line up with the cassette. My hanger had being aligned with parktool DAG-2 for like 10 times. The upper pulley and the cage is always tilted. It shifts fine but when riding, the chain grinds with the cassette teeth due to the tilted upper pulley.
PostPosted: Thu Aug 18, 2016 5:37 am
I have rival wifli RD with force 11 Cassette and Red22 chain. No issues with my set up.
There are no new unread posts for this topic. Sram red rear derailleur issues
NiFTY
19
1463
Tue May 09, 2017 11:32 pm
Gearjunkie View the latest post
There are no new unread posts for this topic. Sram CX1 shifters and X01 rear derailleur
bikemaniack
7
580
Fri Jul 29, 2016 6:38 am
kman View the latest post
There are no new unread posts for this topic. Sram etap rear derailleur problem
srammer
Tue May 30, 2017 4:25 pm
sungod View the latest post
There are no new unread posts for this topic. SRAM hidden bolt design... any issues I should know of?
PartRobot
9
955
Tue Sep 06, 2016 12:39 pm
PartRobot View the latest post
There are no new unread posts for this topic. Campy Rear Derailleur Compatibility
tomato89
Mon Nov 21, 2016 2:44 am
joeyb1000 View the latest post
Users browsing this forum: Bing [Bot], gewichtweenie, LionelB, MyM3Coupe, pyrahna, raggi, Senna993, Ulver and 38 guests
