Best way to replace internal cable routing
ninjanoir78
by ninjanoir78
hi, I have a cannondale super six evo and I want to change my cables, but not sure about the rear brake, it is easy?? what is the best way??
thanks
Ninja
mvacolnago
by mvacolnago
Tie a piece of string on the end of the old cable as you remove it, and then use that string to fish the new cable through.
While fishing the new cable through , push from the cable side and only remove slack from the string side, this will prevent it from coming detached.
justanewbie
by justanewbie
I just pull the old cable out, leaving the housing, put the new cable in the old housing, pull the old housing off the new cable, then slip the new housing on the new cable.
thisisatest
by thisisatest
The rear housing stop comes off, allowing a pretty clear view inside the top tube when fishing the new cable through. Alternatively, if you get a piece of cable liner (like a straw) that is longer than the top tube, you can:
Remove the rear most brake housing,
Slide the straw onto the remaining cable,
Continue to push the straw over the cable so the straw goes through the top tube and exits out the front.
At this point, the straw will span the entire length of the top tube. Tape the ends down, then pull he cable out of the straw. Reverse the procedure to reinstall.
ninjanoir78
by ninjanoir78
justanewbie wrote:I just pull the old cable out, leaving the housing, put the new cable in the old housing, pull the old housing off the new cable, then slip the new housing on the new cable.
there is no housing inside the top tube in the evo frame..
Ninja
ninjanoir78
by ninjanoir78
thisisatest wrote: A
on the front impossible.. from the inside the hole is just big enough for the cable, nothing else ..
anyway thanks, I removed my fork, I took a shifter s housing, put that inside the tiop tube from the back thats it..
Ninja
boolinwall
by boolinwall
I'll second the cable liners. I used to change cables regularly on my Guru Geneo and did it slick as greased pig shit with the use of cable liners.
dhcp
by dhcp
Along this thread - I'm switching a 2013 Roubaix SL4 from Ultegra to SRAM Red and it too has all internal cable routing now. Can you just use the existing housing and poke in new wires for the SRAM or can you reuse the existing Ultegra cables/housing with the SRAM stuff? Or do/should you replace all of it with new stuff (Gore recommended?). Seller I bought the SRAM Red from included (new) internal wires for brakes and derailers, no housings.
Sorry for a newbie question, I've never swapped internal cables before and it seems daunting.
natiedean24
by natiedean24
When all else fails; string and a vacuum cleaner.
justinn
by justinn
As long as the cables aren't rusted out or in need of replacement you should be fine reusing the housing.
spartan
by spartan
simple on the other end place a strong magnet. the steel cable will cling to it. works every time
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
