It is currently Wed Jan 24, 2018 2:30 am
Post new topic  Reply to topic  [ 5 posts ]
 Post subject: Ultegra Ui2 E tubes
PostPosted: Mon May 20, 2013 2:40 pm
I have an issue with my right arm which prevents me from using it to shift. I am equipping my Ui2 Cento 1 with the climbers switch(satellite) SW-R600.I want to install the switch/shifter on the left side but the wire with the switch is too short. Does anyone know if the Shimano etube wires are able to just extend the cable. The shortest I have found online is the 300mm and I have been unable to find the answer in my searches.
thanks
 Post subject: Re: Ultegra Ui2 E tubes
PostPosted: Mon May 20, 2013 10:25 pm
You may use an internal (or external) junction intended for the bb area to plug in an extension.
Alternatively, you can change your Ultegra front junction to a new 3- or 5-port front junction, and simply plug the climbing switch into that.
PostPosted: Tue May 21, 2013 1:45 am
The etube wires are only available with 2 male ends. I don't believe they will work in extending your satellite shifter cable as the ends are designed to go from shifter to junction box which both use the same male connection.
Could you unplug your left shifter entirely and simply plug the satellite shifter into the open junction box location then reprogram it to function as your new front shifter? I haven't used the reprogramming kit myself so I'm unaware of its full capabilities.
PostPosted: Tue May 21, 2013 9:01 am
I would cut off the connector on the cable for the climbing switch and solder a longer on to it.
It's online again:The Machinist
My CAAD10:http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=109014
PostPosted: Wed May 22, 2013 2:28 am
I think you are correct Chello .I looked around and that seems to be the best option. If I splice and solder I would void any warranty on the switch and this way interchangeability is much easier.
There are no new unread posts for this topic. Latex tubes nowadays - best performance tubes for race clinchers
LouisN
28
2501
Fri Jan 19, 2018 1:40 am
LouisN View the latest post
There are no new unread posts for this topic. Patching latex inner tubes
alcatraz
20
1644
Mon Jul 24, 2017 9:39 pm
sanrensho View the latest post
There are no new unread posts for this topic. New Ultegra (Di2) ???
stormur
Thu Mar 23, 2017 10:42 am
stormur View the latest post
There are no new unread posts for this topic. Ultegra brake
Timmy269
Fri Oct 13, 2017 1:08 pm
Timmy269 View the latest post
There are no new unread posts for this topic. Does XT di2 fits to Ultegra di2 shifters [11 sp]
johancoenen59
Thu Jun 01, 2017 2:36 pm
PinaRene View the latest post
Users browsing this forum: albertop07, beanbiken, Bordcla, cycleboyco, Google [Bot], tuba, wobbly and 16 guests
