Dura Ace 9000 compatibility
insightt47
by insightt47
Hi all,
Has anyone tried using 10 speed wheels (i.e Fulcrum 1's) with a Dura Ace 9000 groupset, specifically the cassette? I realise that the DA cassette is 11 speed and has one extra cog on it, therefore theroretically i could just remove 1 cog and it would be compatible with my 10sp wheels?
Also, there is a Fulcrum freehub body available that claims to be compatible with Shimano 9/10/11sp. How is that possible since doesn't the freehub need to be wider to accommodate the wider 11sp cassette?
Thanks in adavnce for your help!
Please use the current topic
OrPe
by OrPe
First, :welcome:
second, did you use search?
good luck.
insightt47
by insightt47
Thanks :) I found a couple of threads but only one person has posted their results regrading removing a cog. I was wondering if anyone else has done it.
