It is currently Wed Jan 17, 2018 6:43 am
Post new topic  Reply to topic  [ 5 posts ]
 Post subject: Saddle Fitment Question
PostPosted: Tue May 14, 2013 9:41 pm
this just dawned on my last night as I was reading about saddle fitment from Cervelo "THE FOUR AND A HALF RULES OF ROAD SADLES" http://www.cervelo.com/en/engineering/a ... dles-.html
specifically on the portion: "Saddle width rule of thumb" section i got to thinking.. by following the measurement suggested then add 2cm or 20mm to the overall center to center measurement, my seatbone measures to 134.62mm (5.3 in.).
so ideally, the '12 toupe pro in 155mm i'm testing out on should work, but it doesn't. i measured the saddle width and in fact it's 155mm or 6.1 inches wide. BUT, here's the kicker.. it's almost towards the end of the saddle where the silver plastic wing sticks out from. also, when it's near the 155mm mark, each side of the saddle (wing part) begans to slope downwards. thus if my seatbone is sitting all the way at the back of the saddle and in between those area, then essentially, my seatbone will be resting towards the sloping part of the wing. which in turns means more pressure to perineum; even with the cutout.
i did a quick diagram here: http://img853.imageshack.us/img853/7139/63021915.jpg
* the red line is the overall width of the saddle; let's assume it's 155mm
* the green line is where my seatbone would rest
the above theory would work as long as the wing part of the saddle doesn't start to slope down and if the width can be more forward rather than backwards.
so that's why i'm thinking maybe the romin pro 2013 with 168mm might work better, since if the wing part does slope down, then at least i know based on my seatbone width, it will be supported on the flat portion of the saddle instead.
i know the only way to test out this theory is to try it.. but it seems only romin offers it in 168mm.. not sure about other companies out that offers such a wide saddle for road bike.
but what do you guys think of my theory.. plausible?
PostPosted: Wed May 15, 2013 12:51 pm
Great read, but the 2cm width rule doesn't always work. According to the Specialized "assometer" I should be on a 143mm saddle. My sit bones are better positioned on a 143mm width but, my thighs rub causing even more pain. So I ride a 130mm Toupe.
If everyone was simply a skeleton with no fat and muscle layers separating the sit bones from the saddle then this would be perfect. However, everyone's body is different.
I know that Specialized used to offer a 30 trial from the day you bought the saddle. If they still do, it would be worth it to pick up the wider one to see if that works for you.
PostPosted: Wed May 15, 2013 8:03 pm
The assometer also said I should be on a 143mm saddle. Tried a 143mm Toupe and it didn't work for me. 130mm is much better. The shop had no problem making the exchange.
The 130mm Toupe (any version- I have a couple) is the best saddle I have used yet.
PostPosted: Wed May 15, 2013 9:07 pm
I run a San Marco Concor Sprint saddle on my road bike which is 134mm wide. I can ride it for as long as I need to. So when I got my MTB a few weeks ago...I figured it would work on that too. Wrong...after about 20 mins on the trail...my ass felt like a pummeled prune. I switched to a Romin Expert in 143mm and no more pain.
What saddle widths you run can also depend on how low you are on the bike. The more upright you are...the more pressure is going to be on your sit bone and lower back.
PostPosted: Thu May 16, 2013 5:45 am
well.. i was able to get a refund on the 2012 toupe pro. funny thing was when i was there.. i saw 2 other returns for the same saddle too. i know it's a personal thing.. so now i'm trying the Selle Italia SLR Superflow 145mm. did a quick ride today to test out the farsport 38mm clinchers and so far saddle felt good. at least it passed the immediate discomfort test. i have more than 30 days to test it out so will put it to good use.
There are no new unread posts for this topic. Cipollini Bond tyre size fitment
Cyclemark
7
778
Mon Jun 26, 2017 7:40 am
Cyclemark View the latest post
There are no new unread posts for this topic. 4iiii dual power meter fitment
mattCSUK
Thu Jun 22, 2017 1:52 pm
mattCSUK View the latest post
mattCSUK
Fri Jun 23, 2017 11:30 pm
gmarsden View the latest post
There are no new unread posts for this topic. Do you use a saddle bag?
survivor
33
1994
Sat Sep 23, 2017 11:51 pm
wicz View the latest post
There are no new unread posts for this topic. How long u'r saddle last?
3Pio
29
2217
Thu Aug 10, 2017 10:00 am
kgt View the latest post
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 41 guests
cron
