It is currently Mon Dec 18, 2017 2:21 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Tue May 14, 2013 7:36 pm
I'm in to process of building up a SuperSix Di2 frame and I'm wondering how much I should be worried about the internal wires being rubbed by the BB30 spindle. With the Shimano bottom brackets there is always a plastic sleeve, but I don't see how I can keep at lease one wire from rubbing the axle unless I hold it to the bottom of the frame with vinyl tape.
Am I just over thinking things? :noidea:
PostPosted: Tue May 14, 2013 8:35 pm
You could use a small length of heat shrink or a drinking straw. It's not necessary though, there's no force pushing the wire against the spindle. It might wear through in 10,000 miles or so. Maybe. But you're probably switching parts and rewiring a little more often than that, right?
PostPosted: Tue May 14, 2013 9:39 pm
I've got over a thousand miles on my SystemSix with a section of yoghurt pot used to hold the Di2 wire away from the rotating axle.
The wire runs in the hole that was previously used to locate the BB wire guide, is held against the inside of the shell by the section of pot, and then runs up the seat tube to the in-seat-post battery.
PostPosted: Tue May 14, 2013 9:57 pm
Agree that it's probably not a huge deal. Are you planning to use a Shimano crank? I recently built a supersix with a Sram PF30 bottom bracket, Sram crank and Di2 transmission. The SRAM BB had a sleeve:
If you're going Shimano crank, consider the Praxis PF30/BB30->Shimano Hollotech adapter. It comes with a sleeve and the adapter design is quite smart:
http://praxiscycles.com/pages/conversion
PostPosted: Tue May 14, 2013 11:35 pm
@415brian I have the Praxis BB in my cross bike and I love it.
I'm going to be running an SiSl2 crank with Spidering gears for this build. I'm trying to save weight where possible. I've posted details in the build thread I've got in the Intro/Gallery section.
PostPosted: Wed May 15, 2013 3:22 am
Gotcha - sounds like you already have a (sleeveless) SiSl2 Cannondale PressFit Bottom Bracket. If you wanted to, could you run a (sleeved) Sram PF30 bottom bracket with the SiSl2 spindle and spacer bits? Now I'm just curious.
Of course, that's probably not worth the money. I'd probably just hide or tape the Di2 wires as best you can.
Your build is similar to mine and that's probably why I think it looks sharp.
PostPosted: Wed May 15, 2013 12:37 pm
I think I'm going to go with a bit of this instead.
Doesn't weigh much and should provide more than enough protection.
PostPosted: Wed May 15, 2013 3:14 pm
good call!
PostPosted: Thu May 16, 2013 4:35 pm
I've done a few bikes like this and have taken PF30 bb's, removed the bearings and cut the cups down so that they fit inside the frame but left them large enough to have friction between the shoulder and the frame. That way they stay centered and have enough friction that they don't spin.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Sat May 18, 2013 1:18 am
I just built up my Parlee Z1 with a PF30 bb with the Cannondale SISL2 Spiderring crankset and the Shimano DA 9079 DI2 drivetrain.
My builder used the Cannondale SL2 68x109 mm Ceramic bb part no. KP247 plus the PF30 shell from the Cannondale Pressfit BB30 PF30 bb shell part no. KP197 because we were concern qthat the DI2 wires might rub against the rotating axle if we used the Cannondale SL2 68x109 mm Pressfit Ceramic bb part no. KP248 that has a bearing PF shell/shield only. You can look up these parts at the www.cannondaleexperts.com site.
Or, you could use the SRAM Pressfit Ceramic BB30 Part no. 12XS267. That was what we used for my Lynskey Helix OS with a PF30 bb with the Cannondale Hollowgram SISL crankset with the SRAM Red drivetrain.
Mark
2012 Lynskey R330 with SRAM Red Quarq
2013 Parlee Z1 with DA 9070
2013 Lynskey Helix OS II with SRAM Red
PostPosted: Sat May 18, 2013 7:04 am
i have a similar concern. i intend to use square taper BB. Those that should have enough clearance to run the wire in between the BB and the shell are -
1) http://www.whiteind.com/bottom-brackets.html
2) http://www.specialites-ta.com/gb/boitier-axix-rte.html
Can anyone suggest others that can be used?
PostPosted: Wed May 22, 2013 8:55 am
Here's another option...a simple rolled up piece of plastic. In this build, I'm using a Praxis BB30 adapter for Shimano Hollowtech cranks.
Photos below. The non-drive-side of the Praxis converter is installed, but not the drive side yet. First picture is the Di2 wires, second is the plastic shield, and the third is the shield installed. It's working surprisingly well. It's light, the wires are protected, and there's zero friction:
PostPosted: Wed May 22, 2013 10:21 am
That's clever, thanks 415brian.
PostPosted: Mon Jun 08, 2015 1:26 am
Did you end up drilling holes in the bottom bracket shell for the Di2 wires?
There are no new unread posts for this topic. Mag 150 with Carbon Axle?
whydobearsxplod
Fri Sep 29, 2017 11:30 am
ms6073 View the latest post
There are no new unread posts for this topic. Thru axle adapter
markyboy
7
347
Wed Dec 13, 2017 12:42 pm
There are no new unread posts for this topic. BSA 68 support for 30[mm] crank axle
Shmitt
10
865
Sun May 07, 2017 1:13 pm
bikerjulio View the latest post
There are no new unread posts for this topic. How far are your bars behind your front wheel axle?
rothwem
44
2236
Thu Nov 16, 2017 4:19 pm
evan326 View the latest post
There are no new unread posts for this topic. Rim brake thru-axle frames/bikes ?
ooo
9
611
Mon Nov 20, 2017 12:21 am
bm0p700f View the latest post
Users browsing this forum: alcatraz, ArtV, joejack951, mrlobber, robikka, Yahoo [Bot] and 38 guests
